SOURCE: We have sound, but no picture
If you replace the lamp and still have no video, the problem could be the ballast. Replacement cost is similar to that of replacing the lamp.
SOURCE: Replace Light Engine
I have the 62HM95 and my light engine went out between 2 and 3 years. I will never buy a Toshiba again. I have had nothing but trouble with the components and the customer support. I am in a class action lawsuit with them, but I doubt very much will come of it.
As far as fixing your TV I was in the same delimma as you. I wasn't willing to pay nearly $1000 to get this set repaired when it already cost $3000 and it started having problems within the year and major issues after 2-3 years. I was willing to risk a couple hundred bucks that I could fix it myself. If you aren't very handy with taking things apart and putting them back together, by all means don't do this. It is pretty easy to do and you can figure it out as you go, but I wouldn't suggest you doing this if you weren't willing to take the risk of really messing it up.
I didn't go to Part Store.com because they wanted $456 and then when I finally decided to do it they raised the price to $556...No way, I found http://www.tristatemodule.com/html/light_engines.html and you can get a light engine that is refurbished for $250, or you can have your light engine refurbished for $200, which is what I plan to do if this one fails in the next two years. I looked at their site and it doesn't show that they have any in stock, but they may if you call. I wasn't comfortable sending mine off to be refurbished because I wasn't sure if I would remember how to put it back together, and I'm glad I didn't because the one they sent me didn't work, which sucks, but it happens. I called them back and sent it back to them and it worked fine. All in all, I had no instructions or any other help besides my memory of how I disassembled it and it only took me an hour at the most, not really too hard.
The only other issue I had with them and it really wasn't with them as much as Toshiba is, I received a light engine for a 46" model, which when I talked to Toshiba they swore up and down that it wouldn't work, when I talked to TriState about it they said that Toshiba would say that and they had used it in 1,000's of 62" models and it's worked fine. After they replaced the broken one they sent originally, the new one worked fine and is still working brilliantly and I have my original 62" light engine to get refurbished if anything should happen again. Their shipping time was good and when I returned the product to them, I received a working part pretty quickly.
For $250, this would be the only way I would go. If this hadn't worked, I probably would have just went out and got a different TV. I hope this helps.
Michael
SOURCE: no pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
SOURCE: Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
SOURCE: Hi: My Toshiba starting showing the symptoms (as
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
