Question about Apple STUDIO DISPLAY 21" Monitor
Monitor is black at start up
Led blinks green but won't come on. I've switched out monitors and it's not the monitor. I also replaced the video card , no good. Power supply is 300 watts and I was told that could be the problem. Any help would be appreciated. Jimcoco
I have a IC cn5560 I removed the battery on the motherboard in an attemt to reset the bios.Now all I get is a black screen.The system is not amack it is xp>How do I reset The opperating system? Jp
Posted on Dec 15, 2007
  • joel pitts Dec 15, 2007
    what are Command and option button?
  • 4 Answers
Do you hear any noise at all on start up? Drive spin?
Power supply could be the problem but have you tried replacing the PRAM battery or at least zapping the PRAM?
Press start and immediately hold Command+Option+P+R and wait for two or three chimes, then let go.
Or try resetting your NVRAM in Open Firmware:
Start up with the Cmd+Opt+O+F keys depressed.
When the open firmware screen appears, type in the following after the "0 >" prompts:
0 > reset-nvram
Press Return
0 > reset-all
Press Return
After pressing the second return, the Mac should restart on it's own if the rest was successful. If not, enter the following to restart, or simply power down with the power button:
0 > mac-boot
Press Return
Or try removing the battery (if you know it's good) for 20 minutes, then replace. (Does the same as NVRAM reset)
You can also try resetting the SMU or CUDA button depending on which machine you have.
If you have the machine starting up OK but no video, don't forget the possibility that the video cable could have a problem like a bent pin.
Posted on Nov 16, 2007
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Was watching a movie on my computer last night and all the sudden the screen started turning off and on with no picture when it was on. Has the monitor gone bad or is it a video card issue?
The simple way to check if this is a Monitor issue or not, you can unplug the monitor from the Computer and connect it only to the power outlet. If it gives you a "No signal" screen or goes through any sort of other Self test, Your monitor is fine. You can also check if the power led is blinking Amber or Green. A blinking Amber LED while the monitor is only connected to the Wall outlet indicates the monitor is faulty.
Thank you for using Fixya
Oct 08, 2009 | Dell E173FP 17" LCD Monitor
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Screen turns black and blue LED is blinking
Sounds like the monitor is being made to show a resolution it does not support. Check the available resolutions the monitor supports and then check what resolution the video card is giving, if it not compatable, you get the black and blue screens.
For the video card, right click on the desktop in a an empty area and choose properties > settings > your resolution from the card will be there. Now from there click on advanced > click on monitor and look at the monitor settings. Make sure the box is checked to hide modes the monitor cannot display. Now click on the adapter tab and click below on all modes. This is the list of all modes that both the monitor and the video card argree on. Make sure the settings in your game match one of these and you should be good to go.
Sep 14, 2009 | LG Studioworks 563N 15" CRT Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Hansol Mazellan 500A is it not compatible with 128MB Video Card?
your monitor does not support the screen resolution that your windows install is set to. hook your pc back up to your computer guys monitor, and reduce the screen resolution, then hook it back up to your monitor.
Jan 08, 2008 | Hansol 500 A Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
137 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
