Here is a list of Subaru diagnosis codes. If these are not what you are coming up with let me know the numbers you are getting and I will look them up on my genisys scanner to further assist you. 1111 No codes stored 11 Crankshaft
position sensor (Don't confuse with above, usually when the crankshaft
sensor if dodgy the thing won't start anyway) 12 Starter switch faulty 13 Camshaft position sensor 14 Injector no.1 15 Injector no.2 16 Injector no.3 17 Injector No.4 21 Engine temp sensor 22 Knock sensor 23 Mass air flow sensor 24 Idle air control sensor (usually accompanied by running too fast/slow) 31 Throttle position sensor 32 O2 sensor 33 Vehicle speed sensor 35 Emissions canister purge valve 38 Torque control signal (Automatics) 42 Closed throttle position 44 Turbo wastegate regulator malfunction 45 MAP sensor 49 CO adjustment resistor for older cars not fitted with cats 51 Neutral switch (Manual gearbox)
If your planning on installing on of those so called chips, don't bother. It is just a .25 cent resistor that will cause more issues in the long run. Trust me on this one.
Check your IAT . It controls fuel supply at start up. If it tells the computer the motor is cold it will flood the engine giving it extra fuel. Good luck and have a great day.
BE CAREFUL.... If the part you are installing is the .19 Cent diode you should really understand what it does and if it was really that good an idea, don't you think Subaru would have done it at the factory. There are alot of Ebayers that are making a killing off of selling the .19 cent diode and a piece of paper with directions for about $5 a pop.
