Question about HTC TyTN Smartphone
Stylus not responding
Stylus does not work on the tytn
  • sjoerd Oct 21, 2008
    Finger will work, stylus doesn't react.
  • 30 Answers
IF the above solution dosent work then you can try pushing little more with stylus or use your thumb, other wise take to shop and let them clean the phone specially under screen. ( warning DO NOT try to TAKE screen your self: Its complicated and it takes special tools)
Posted on Jul 08, 2009
  • 25 Answers
Have you tried a reset of the phone by pushing the stylus into the small hole in the bottom of the device?
Try this, and see if it picks up the stylus touches again.
Posted on Jul 07, 2009
Often when I touch my screen it doesn't respond,why?
did you try calibrating the touch screen? i would first do a hard reset then go to Start> Settings> System tab> Screen> General tab> Align Screen. try using a stylus instead of fingers too! worked for mine
Mar 13, 2011 | HTC TyTN II Smartphone
My htc tytn II is showing four color screen when ever i switch it on.
Hi, I'm not sure if this is the right way, but here what I did when I faced this problem [ 30 min ago]
after switching on the phone [it was "on" while I was searching for solution], insert the stylus into the reset hole [found on the bottom].
Dec 20, 2009 | HTC TyTN II Smartphone
All the keys on my phone do not respond
looks like your keyboard is damaged and will need repairing.
Jan 10, 2009 | HTC TYTN GSM Phone
Hard reset for a HTC TyTn
There are two ways:
1.
Press and hold the two soft keys (the ones with dashes on) and at the same time insert the stylus in the soft reset hole. All three things need to be done together and a warning will appear. (it is a bit fiddly)
Go to Start>Settings>System (Tab)>Clear Storage (Icon)
Mike
Sep 14, 2008 | HTC TyTN Smartphone
TyTN II - Keep the phone screen alice during a call
Received the following reponse very promptly from HTC Support
---Quote---
This is actually a function of the phone and not a fault. It was designed so that when you were on a call and had the phone against your ear that you didn't accidently tap on the screen and open functions or end the call etc. If you wish to access the touchscreen while on the phone you can press the power button on the side of the phone to turn the screen back on. I have attached a 3rd Party Application that allows the screen to stay on while you are on a call. Follow the below steps to install the program. Attached is a patch for the TyTN II screen blackout issue.
This is not an official fix.
  1. Copy the KaiserTweak.zip folder to your pc's desktop.
  2. Connect you device to the pc via ActiveSync.
  3. Use the Explore function in Active Sync to copy the KaiserTweak.zip folder to the windows directory on your TYTN II.
  4. Disconnect your TYTN II from the pc.
  5. Open up file explorer on your TYTN II and go to the windows directory
  6. Unzip the folder to the windows directory on the TYTN II
  7. Run the Kaiser Tweak.exe to install the patch.
  8. Adopt the recommended configs, not the default.
  9. Soft reset the TYTN II by pressing the stylus into the little circle hole on the bottom of the handset.
If it doesn't work first time hard reset and try again. ---End Quote --- Thanks to the FixYa guys for thier intererst in this topic and problem Cheers Corpcc
May 12, 2008 | HTC TyTN Smartphone
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
HTC TyTn front buttons not working
Same problem...
Bet it's a software glitch
Mar 06, 2008 | HTC TyTN Smartphone
Touch screen not working...
Hi guys,
i post this solution for those wo will be in the same situation in th next future. I had the same problem with my HTC TyTN (Herm 200). The touch-screen was simply not working. I read many 'solutions' on the net but none worked. I did not try the hard-reset because i was convinced this is not a software problem, and resetting the WM5 will not help. So i brushed the corners, looked for small particles which were pressing on the cover of the touch screen. but it did not work. finally i found one post (i don't remember where exactly) where a guy used a credit card and pushed it all around the touch-screen under the metal case (a bit harder). i tried it and it worked. i pressed harder especially in the lower part, above the buttons. and simply it worked ! no problem since then.
Feb 26, 2008 | HTC TyTN Smartphone
Dopod 838 pro touchscreen not working
Have you tried a hard reset?
(Hold in the power button why pressing the stylus in the reset button on the bottom of the phone)
Jan 29, 2008 | HTC TyTN Smartphone
HTC TyTN Smartphone Logo
149 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
