How to print #10 Envelopes
How do I print #10 envelopes on the Bizhub Di5510?
I need to print out a large batch - not sure what tray to use, etc...
  • Anonymous May 02, 2008
    I do not know how to print a large number of envelopes on the Canon 3045.
  • Anonymous Mar 12, 2014
    all large and gold envelopes/printing machine
  • Office Equip... Master
  • 6,595 Answers
How to copy/print onto envelopes.
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Posted on Aug 01, 2009
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
How do i print a # 10 business envelope with the bizhub c200
First recommended that you use the bypass tray on the right side, also before placing the envelope in the bypass tray send the print job over first, the screen will say replenish paper then go ahead and place the envelope on the tray. and let it take it or hit the start button Ensure you select #10 commercial media and bypass tray in your print driver preferences. May also want to have tech come out and look at the tray and run MAX and Min. Adjustments.
Oct 09, 2012 | Minolta bizhub 200 All-In-One Printer
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
Feb 15, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
How do I get our Bizhub 350 to print on envelopes.
Create your document at the appropriate size, #10 Env.
On the device, set the BYPASS tray to a size setting of the same. Look under the custome sizes as there may already be one there.
There is a switch just inside the device, near the bypass tray where you set it for envelopes. this opens up the feed gap to allow for the thicker envelopes.
this is all contained in the manual.
Dec 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
Need EASY directions to print envelopes!
At the print que select the bypass tray as the paper source and envelope as paper type and make sure to set the envelope size like # 10 or whatever size they are. Make sure not to print envelopes with windows.
-Carl, please let me know if this helps.
Apr 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
You MUST use the bypass tray and bve sure to enter the custom size, media type and weight in the driver. The settings MUST be set the same on the 180 before printing.
Running envelopes is a tricky situation, but once mastered it should work. Note that not all envelopes will run, try different sizes and brands and keep the ones that work.
Nov 16, 2007 | Konica Minolta bizhub 180 All-In-One...
638 people viewed this question
