Question about Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard
Turns on and off repeatedly
Im not sure if its even the motherboard but i checked my ram and power supply and they are fine.My problem is that 5 seconds into booting up it shuts itsself down and repeats the process over and over.
  • 1 more comment
  • Daniel Porzondek
    Daniel Porzondek Nov 14, 2007
    I dont see a jumper next to the battery
  • Daniel Porzondek
  • ccrozier_agr
    ccrozier_agr Nov 27, 2008
    Turns on then goes off 5 seconds later .
  • 121 Answers
Try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
ps: if the mainboard bottom was in touch with anything metal from the case then reboots will occure repeatedly and the board might get damaged.
Posted on Nov 13, 2007
  • Fakher eddine Ghosn
    Fakher eddine Ghosn Nov 14, 2007
    look close enough ....impossible ....there must be smthing written beneath it like ( jbat) smtimes its yello color
    it might be above the cmos battery
Dell e5520 freezing
1. Dying power-supply is creating unstable voltages
2. Dying capacitors on motherboard are unable to stabilize voltages
3. bad RAM (compare to writing in pen on greasy paper -- nothing is realiably being recorded)
4. bad spots on disk-drive (computer is spending too much time trying to write to those "bad" spots)
5. other "dying" issues with the motherboard
1. different power supply
2. if you have more than one stick of RAM, remove one and test-drive. Repeat with the other stick(s).
3. Try different RAM.
4. Force CHKDSK ("Check Disk") utility to scan *all* of the disk-drive.
5 Inspect the motherboard for bulging/leaking capacitors.
6. Replace the motherboard.
7. Replace the whole computer.
May 27, 2014 | Dell Computers & Internet
My pc turn on only the fan in 5 seconde
check all power plugins on board the make sure that the power supply is good and check ram to be in all the way
Feb 28, 2013 | EliteGroup G41TM (V10) (G41TM(10))...
My computer won't turn on but the light on the motherboard turns on when i swicth the power supply on. I've already tested the power supply on a different motherboard and it works just fine. I've also...
Try reseating the RAM modules, if it still doesn't work, remove the RAM and test the RAM in another computer or at your friendly computer store.
Sep 03, 2010 | IBM Computers & Internet
Please help me to identify my problem
The system beeps when you remove the RAM. This means that POST is working correctly and the motherboard may be fine.
Check that the monitor cable connector that connects to the video card isn't loosely connected.
When you insert the RAM, there's no display. This may mean that the RAM is detected but still faulty. Try using another RAM, if you can. Also remove the Video card (if you have a separate video card). Then, re-insert it firmly, and power up the system once again.
If you don't have a separate video card, you should test the motherboard on the bench, that is outside the computer case. Remove the motherboard, RAM and power supply (and the video card if it's separate). Put it on the bench and power it up as shown here:
You'd need to closely look on the motherboard to see which pins are for the power switch (marked as PW-SW, PWR, PWR-SW, PWR-ON etc). Then, short them with a screw driver, for a second, to turn the system ON.
Replace the RAM and the video card one by one, if the system doesn't give any display even on the bench. This way you can find out what is the problem.
Hope that helps,
Mar 26, 2010 | Intel D845GVSR Motherboard
M4A785TD-M EVO Motherboard will not boot.
From what you are descrbing it sounds like a PSU issue
Please try the following
1) Remove all the wires from the PC
2) Press and hold the power button in for about 10 seconds (yes i know there is no power :) )
3) Plug everything back in and retry, if it still fails the Power supply will need to be changed
The Power supply can be swapped out at any decent PC repair shop and is quite cheap to do
I hope this helps
Mar 08, 2010 | ASUS M4A785TD-V EVO Motherboard
No Power On Start
Problem Solved, changed the power supply with a 450watt one and it booted fine .
Jan 30, 2009 | PC Chips P25G Motherboard
Main board won't power up
I would start by removing all of the cards on the mobo, add 1 and reboot, rinse and repeat until you find the bad card, even the ram which I would start with myself, I have had an agp card do this to me.
Like to know where the click is coming from. When you say the power supply is fine, how can you be sure? May fail under a load. Not the only solution to be sure, but a good place to start.
Jan 24, 2009 | ASUS A7S333 Motherboard
Flashing Green Light on Power BESTEC Power Supply
Hi. NO, *********** board is not fried. I am not sure what the problem is but I do know how to fix it. It is usually casued by power outages (even if you have UPS supply).
1. TAKE OUT THE ELECTRICITY LEAD TO THE COMPUTER. Look inside the computer and find the bunch of wires coming from the power supply unit (the box thing at the top with the fan and all those colouted wires!).
2. Find where these wires run into a plastic connector and plug into the mother board. Unplug it.
3. Now plug the electicity lead back into the computer. The light should now stay ON.
4. Plug in the connector again... and boot up. Leave it run a while to convince it!
5. Repeat this process if it does not work first time.
This should fix your problem . It works for me when I get this problem.
Friend in Spain
Jan 10, 2009 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
So i was trying to change out the ram for a better on. while doing that i decided that i was going to clean out the insides, mainly cause its never been done. also while doing this, i took out the...
Make sure the cpu is seated properly. It should only go in one way. Also make sure you have applied a good thermal paste between the cpu & heatsink. Check and reseat RAM. Then try rebooting. Hope this helps.
Dec 25, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
