The board is also used here: RLED4010A X322BV PLCD5092A-B X425BV
SOURCE: upside down picture
OK this would denote that somehow your deflection (verticle) has been switched. I would have to see what the service documentation has to say about this, if you can contact the manufacture and get the service documents I or someone else can actually help with this problem. It is actually a simple problem but the service documentation will show how to correct it properly.
SOURCE: Aquos picture upside down
Go to the setup menu and look for "FLIP" Its all a matter of Menu setup,
Best regards
CircuitCity
SOURCE: Picture is upside down on screen
go into the menu using either your remote or the button on the projector itself. At the top are several options i.e. "picture" scr-adj. Click over to the right ONCE to "SCR-ADJ" this stands for source adjust. Then look for something called like PRJ mode (projection mode) This tells the projector which direction to display the image so that incase you want to hang it from the ceiling upside down you can. Click down to that menu option. You will then have to click over to the right in order to see your options. If you are using it hanging on a ceiling you want it to say "ceiling front" if it is merely sitting on a cart or a shelf just put it on "front".
Good luck.
SOURCE: picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
SOURCE: I mounted my In Focus Projector upside down
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
