Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Nat settings Hi mate i need to open my nat settings on my wireless g plus router my xbox360 informs me i have to change the settings
  • 1 more comment
  • Anonymous Nov 26, 2007
    yes do any ports have to be opened has any one got a step by step guide as to how to do it.
  • welshlass69 Jun 11, 2008
    my nat is only open on moderate on my xbox 360 live can you help?
  • ryno021 Jan 25, 2009
    i have the same problem as him i need help BADLY please
Go to the router home page ( and click on firewall NOT ANY OF THE SUB CATAGORIES AND DISABLE THE FIREWALL and it will AT LEAST go to moderate nat
Posted on Jul 11, 2008
    Problem Solver:
  • 7 Answers
Try going to default user name and password is admin for both. go to your wireless security and set up security as xbox allows. i think i set mine up with wpa and all i had to do was put the code into the xbox settings after the router page generated an encrypted key sequence.
Posted on Nov 14, 2007
Open my nat for ps3
You may need to change some settings on the router.
Also you may need to open the ports on the router for PS3.
If you are using DSL Internet service then make sure that modem is in Bridge or PPPoE mode.
Read How to change NAT type to open for gaming devices
Jun 23, 2012 | Belkin Wireless G Plus MIMO (F5D9230-4)...
1- Using your Browser, Log on to your router (by normally typing in the address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
Opening NAT with belkin wireless router xbox360
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jul 29, 2010 | Zyxel P660HW-D1 Router
NAT on xbox live is moderate! i need it to be open, for best results. What do i need to do?
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Jan 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to open my NAT type for xbox live
You can contact NETGEAR support to help you open the NAT settings. ( they know how to do it )
The simplest way and most efficient way to connect to xbox live is using DIRECT MODEM CONNECTION
For compatible list of devices and internet service provider, please check the website ( )
Apr 14, 2009 | Microsoft Video Game Consoles & Games
Opening NAT for xbox360 on WPN824
u need to loginto the router page
on the left side of the screen u will see an option called WANsetup under advanced
1.disable spi firewall
2.nat filtering to open
apply the setting
it must work
Dec 14, 2008 | NetGear RangeMax WPN824 Wireless Router...
How to change my NAT
You need to check first if your router is Xbox Live compatible (all routers will work, but only certain ones will allow an open NAT):
If your router IS on the list, make sure you have a compatible firmware version (usually the firmware version is written on the router somewhere). If you do not have the proper firmware, you will need to downgrade your firmware (reply to me for instructions on this).
If your router is not on the list, you're outta luck.
May 21, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Nat type
I have the same router (WRT300N) and this is what I did. I don't know if it will work for more than one Xbox360.
- Go to the Setting of the router.
- Applications & Gaming
- DMZ
. Enable the DMZ
. Choice the Mac Adress under the Destination.
. If you don't know the Mac Adress of your Xbox360 click on the tab: DHCP CLIENT TABLE
.Now from there choice your Xbox360 ( the Xbox360 won't have a Client Name but hopefully you only have your Xbox360 and your computer)
and now save your setting and restart your Xbox360 and there you go NAT open. This also help if you get any kind of  LAG while someone is on the computer using the internet, your Xbox360 will be high priorty to the router.
Apr 05, 2008 | Linksys WRT300N Wireless Router
Set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Jan 19, 2008 | Zyxel Prestige 660HW Wireless Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
918 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
