Question about Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset
My Sony Bluetooth problem
I have a problem with my sony 750i. It does not accept pictures or songs from other mobiles through bluetooth. It shows memory is full and delete some files. Even when I did so, it does not get connected. Kindly advise me.
  • 590 Answers
Re: My Sony Bluetooth problem
Deleting files from your memory card is not enough. Usually the files received threw bluetooth will stored to phone memory and then prompted to store somewhere else by the user. So delete/move unwanted files from phone memory to memory card. Delete all the messages stored in your SIM card too.
Posted on Jul 29, 2009
0 characters
3 Points
Sony ericsson bluetooth headset tryin yo connect
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Nov 18, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
Can't get pairing between phone and hands free because I don't know the passcode for BDA-2
Hi Sstoward,
Have you tried 0000
Most default bluetooth passkeys are usually set as that.
I have also found the manual for this and it mentions the same passkey:
HCB-700 User guide
Oct 19, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing workss....
Jan 03, 2009 | Sony Ericsson Sony-Ericsson HBH608...
Hi there, I have been getting low signal problem.. also when i speaking with my friends its got call ends itself. And more often its shows "Emergency". Could u please Help me ASAP
Oct 23, 2008 | Sony Ericsson Mobile Bluetooth Car Kit...
Please need help urgently
You should press both + and - button on your head set and wait until green light turns into red.
May 13, 2008 | Sony Ericsson HBH-PV705 Headset
Sony ericson charging
tried flashing it?
it maybe corrupted firmware thats what i would do.
Jan 11, 2008 | Sony Ericsson Mobile Bluetooth Car Kit...
Sony ericsson w550i
when a file is sent to the folder named other, it usually means the fone cannot play the desired file.
thank you
Sep 27, 2007 | Sony Ericsson HBH-610a (Auto Pairing)...
Compatability bluetooth headset K 750i/K800
Hi, The way that I paired my device is by pressing and holding the two volume buttons simultaneously for about 5 seconds, until the red and green lights began to appear. Then, i just 'refreshed' my bluetooth search for devices, and it discovered it, and was able to pair it up. Hopefully, this is useful
Oct 18, 2006 | Sony Ericsson HBH-610a (Auto Pairing)...
Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset Logo
62 people viewed this question
Top Sony Ericsson Headsets Experts
Justin Peters
 Mike M
Mike M
Are you a Sony Ericsson Headset Expert? Answer questions, earn points and help others
