Question about Brother IntelliFAX 2800 Laser Fax
Auto paper feeder not taking paper
Anything we try recieving faxes copying etc we get message no paper feed . (note recent move in truck could it be "jarred" too hard and loosened something or some fuse?
  • Anonymous Dec 20, 2007
    Fax ran out of paper. Now it won't take any paper I put in
    it. The rollers are not rolling to try to pick up the
    paper. Can't receive any faxes in a busy office.
  • 159 Answers
Try removing the paper, then removing the drum from the machine. Check to see there are no obstructions, then re-insert the drum, making sure that the gears mesh properly. Load the paper, setting the paper width guides and then try printing a report.
Posted on Dec 24, 2007
Check to make sure that the rollers are in good condition inside the top feeder.
Also make sure that there is NO object or anything that the paper is hitting against by manually feeding the paper and carefully observe the paper path
May 03, 2011 | Canon Office Equipment & Supplies
I am feeding a portrait fax letter size and it is being received partially - one half is cut off. please explain
It sounds as if the document feeder is not recognizing the proper size of paper. Try making a copy, is the copy correct or is the copier indicating to load a certain size of paper. The paper width guides as well as the raised tabs on the document feeder tell the copier the proper paper size. Could the problem be on the other end? I know I have several customers that have the paper size dials or indicators incorrect for the paper in their cassettes. This would be if only a single reciever of your fax is complaining. You may want to see if rotating the fax in the LTR-R direction works.
Dec 03, 2010 | Canon imageRUNNER 4570 Copier
Enter copies into the feeder (Canon 210S). It
This is one of the worest designed feeder from Canon. Have you had the feeder rebuilt recently? If not that will improve it greatly. I would also, go into the user settings and turn the fax exit to recurite late doc. As I said, it is a bear to take this feeder apart if you have not done it before... Good Luck
Mar 05, 2010 | Canon imageRUNNER 210S Copier
Fax T 104, can recieve but not send. Can hear the fax signal fro
When you hear the fax signal press the start button on your machine. If this does not work attempt to just make a copy of a document without sending to test the document feeder - help the document by gently pushing the document into the machine when it should be feeding. If you can feel the machine trying to grab it but it doesn't have enough strentgh or it will feed with your help then the feed rollers are probably dirty and you may be able to open up the top cover and clean the rubber rollers with alcohol or degreaser. If the feed rollers do not even turn when trying to make a copy then you may have a motor, belt or clutch problem. If it copies well but will not send, then you will probably have a modem or fax lead problem. Try a new fax lead.
Jul 08, 2009 | Brother Office Equipment & Supplies
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Samsung scx-4521f lines on feeder scan
Youll find that the most common problem with fax machines is that the scanner head that the paper passes over actually gets gritty and dirty. Remember it only takes a spek sitting in there.
Try a damp cloth (not to much Water) and wipe down the sensor reader, It will take a little bit of trial and error but mainly this is the common problem. also try wiping down all the wheels and rollers that the paper runs over as well. Otherwise it could be the recieval end that has a dirty paper feed wheel.
Sometimes it is also common that the internal scanner/sensor reader wears out and needs replacement.
IF this is the case its generally cheaper to buy another fax. Hopefully the above helps for you so you dont have to buy another one
Apr 01, 2009 | Office Equipment & Supplies
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Sheet feeder isn't working
which feeder? for the oringinal copy? or the blank paper. Either way it sounds like the rubber feed rollers need to be cleaned. With a rag and some rubbing alcohol clean all rubber rollers.
Jun 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother IntelliFAX 2800 Laser Fax Logo
76 people viewed this question
James Cagle
James Cagle
Jim Keysor
