Hello Karolina
My name is Peter. I am a retired field service appliance technician.
Please do not change the breaker. If your fan is running then you have power to your unit.
I wish some of the sites advisers would not give advice in areas where they are not knowledgeable just to built up points!
You have to be careful. This un-experienced adviser could have cost you several hundred dollars for a new breaker and he would not be liable.
Now, lets address your problem.
You need to provide me with your oven model number, which is located on a metal plate on the top face of your oven when you open the door.
You could just have a bad sensor or component.
Send me your model number and I will help you.
Hello Peter. Thank you very much for you answer. It is model GDF 603, serial number is 24710 0075, fab no.0075.
Hello Karolina, Is this Majic Chef? Then I can help you. If you live in the UK, is this a Delonghi? I live in Glen Burnie, Maryland, USA. In this case I do not have access to this manufacturers wiring diagrams.
I assume this is electric full-size oven, not Microwave? Check
the Oven circuit breaker which should be a large 220vac breaker.
Turn off and back on. If the problem reoccurs. The Breaker is "tired" and needs to be replaced by an Electrician.
Yes, it is electric full size oven.
Is corcuit breaker the same as selector switch ? Sorry to bother you but I'm a woman and trying to sort this out as much as possible before I'll pay fortune to some specialist electrician :)
No, The circuit breaker is one of the big ones in your main circuit breaker box. The main box is usually inside near the electric meter outside. If an older house it may be a "fuse" box with two large fuses. Hopefully that is not your arrangement. It is deadly scary to change those fuses.
