Question about Coby MP-C741 MP3 Player
Coby mp3 I can't read the words on my screen when in the options screen. All the words are now random symbols that don't make any sense. Can you please tell me how to fix this problem?
2 Suggested Answers
  • 209 Answers
SOURCE: my coby mp3
Try connecting it, opening My Computer look for coby-something, open it, and drag your files to the correct folder.
Please rate or respond if you need more help.
Posted on Jan 20, 2008
  • 2335 Answers
SOURCE: i plug my coby mp3 n the computer can't read it
Here are instructions for a solution to your frozen Coby 610 problem. This works even though the MP3 player is having problems talking to your computer. They should communicate fine after this update.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Posted on Jan 17, 2010
0 characters
1 Points
Unable to select random option, or any other option!
It does not say so in the manual, but you must hold down the Enter key (the center round button) and while doing that, press the Option button (the equals on the right).
Nov 17, 2013 | Coby MP707 MP3 Player
How do you get the player to play random songs
While your playing a song, press the gear at the top right of the screen, here is where you can change the repeat option to your preference using onscreen menu.
Aug 19, 2011 | Coby MP828 layer
I have a coby mp828 and I am trying to shuffle songs. I have the random function highlighted and it still won't shuffle..Any ideas
Start playing a track. Click anywhere on screen. Options should show at top of screen. Click on the tool symbol (should look like a bolt.) Click on repeat mode. Click random. This should solve your problem.
Jun 19, 2011 | Coby MP828 MP3 Player
Turn On Shuffle on Coby MP 610 - 8GB
While playing a song, press the Quick Options Menu button (small circle), you will see an option for "REPEAT", choose from:
No Repeat Play tracks in normal order and
no repeat.
One Play the current track repeatedly.
All Play all tracks repeatedly.
RandomAll Play all tracks in random order.
Dir Normal Repeat all tracks in the current
Dir Rep Repeat all tracks in all folders.
Dir Random Play folders in random order.
Jun 01, 2010 | Coby MP-610 MP3 Player
Why does sony E436F MP3 player change the order of the songs
Your music has likely been put on shuffle. Look on the screen while songs are playing. You will see two crossed arrows or the word shuffle or random. Check playback options and see if random or shuffle option has been turned on. Sometimes the program you use to put songs on the MP3 player will activate this option if the program's playlist is on shuffle.
Dec 16, 2009 | Sony NWZ-E436F MP3 Player
Coby 610-2g won't turn on or charge
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
Unfreeze Coby 610
Jun 03, 2009 | Coby MP-610 MP3 Player
It on a red screen it on but wont go any were
All mine does is flash the word coby on and off and wont do nothing else.
Jan 20, 2008 | Coby MPC-848 MP3 Player
No options
tech support at tele 1 800 681 2629 or by email at good luck
Oct 03, 2006 | Coby MPC-848 MP3 Player
Coby MP-C741 MP3 Player Logo
18 people viewed this question
Top Coby MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Coby MP3 and Digital Media Player Expert? Answer questions, earn points and help others
