can only be a few of the following-
*power source from wall outlet
*GFI reset on wall outlet
*Plug or cord damage(d)
*Brushes in electric motor are worn
it sounds like the motor is dead. The Light and the motor are wired differently so it is quite possible that the motor is dead and the light still works.
The vac very likely has a thermostat located near the suction motor that will stop the motor to keep it from burning itself out. These thermostats rarely go bad. You need to look for a blockage starting with the power nozzel (carpet sweeper) all the way to the canister. Take the hose from the canister and power nozzel and drop a coin in one side and see if it comes out the other end. If not, try pushing a broom stick thru to move the blockage to the other end and get it out with needle nose plyers. Don't use a coat hanger!
You can take the carpet sweeper loose from the wands and look into the elbow (part that swivels) for a blockage. It all has to do with air flow to keep the motor cool.
Joe
Generic problem for all Vacuums Hi my vacuum (Russell Hobss 2200 Bagless HEPA) Hi my vacuum (Russell Hobss 2200 Bagless HEPA) seems to have just enough (not loads) of suction till it reaches the cleaning head. The head does not appear to be blocked - but there is then almost no suction at all. It also makes loads of noise when on- and an even louder noise when turning off. is it fixable or is it dead? Thanks I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Well there seems to be maybe a few problems, the head may be clear, but the hoses could be clogged and or the HEPA filter could be clogged as well – if the hoses and wands are clear and the filter clean you may look @ a motor replacement depending on the cost or to buy a new vacuum and in some instances you can trade in your old vacuum for a new one – but check it fist from the suction head thru the hoses, wands and filters, B4 you decide to purchase a new one or to replace the old motor with a new one depending on cost. A rule to live by – the item cost more to repair that to replace – replace the item, if the repair cost (as an example) say $50.00 to $60.00 and to buy a new one would cost $100.00 – buy a new one. Don – The Vac Man
