MAV3757AWW The drum is loose in my topload washer. Extreme vibration when spins.
SOURCE: Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
SOURCE: drum is loose and banging on hotpoint aquarius wf541
This sounds like a classic case of main drum bearing or drum support failure, it is a major repair and not really a DIY repair, unless you are coversant with w/m's
It involves a complete strip down and in some cases it is neccessery to to have to replace the drum as well.
The cost of the parts involved is well in excess of £100.00,and it really is not an economical repair.
I think you would be better off buying a new washer.
Plz rate my solution.
Thanks.
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
SOURCE: Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
SOURCE: EXTREME SHAKING DURING SPIN CYCLE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
