Thermador SC302T Electric Double Oven
Problem for Thermador SC302T Electric Double Oven
Thermador SC301T heating elements not working (top
By thunder_bolt on Jul 09, 2009
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Comments:
Jul 09, 2009
- I thought because both top and bottom elements were not working at the same time it might be something else.... is that possible that if just one is not working neither will work? Both were working fine and suddenly neither are working... thanks for your feedback and any additional feedback would be appreciated. Tony
Solution #1
posted on Jul 09, 2009
Not Rated)
localwonder
Rank: Guru  Ovens & Ranges  Expert
Rating: 92%, 2801 votes
HI, these element should be tested. it is very hard to tell if they are ok by looking.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
A burned out heating element will show no continuity when measured with a meter.
Was this helpful?
Yes
No
Popular Solutions for Thermador SC302T Electric
Questions and Unsolved Problems for Thermador SC302T Electric
Do you recommend Thermador SC302T Electric Double Oven?
Answer
Answer
While trying to clean the display window (for time, etc..) on my Thermador SCD302T oven I... (More)
Answer
what are herman e curtis and the dusky devastators songs
Answer
Thermador range with electric oven model gsc30cvb. Plasma display panel (oven temperature and... (More)
Answer
thermador oven element - seems soldered in place, not screwed..
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Thermador SC302T Electric...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
