Question about Kensington (K33348) Bluetooth Wireless Adapter
Link devices how to i get the adapter to show up on my comptuer. i'm trying to link my jawbone to my pc
Re: link devices
I have a blackberry 8310 curve and a jawbone II (the newest jawbone headset) and really have a two part question. 1st is that i have had the kensington 33348 usb bluetooth adapter for a couple of years and don't remember the key (password, etc.). 2nd it will not see my jawbone headset even in pairing mode. i have played around with these comm ports and may have messed them up. i also tried to update my driver for the kensington and it said no updates needed at this time. please help.
Posted on Oct 04, 2008
0 characters
3 Points
Hello, I am almost certain that the problem is
Sorry for the delay in responds.
From what i have read. you have already tried most of the fixes. There is still a couple of things we can try.
Instead of using the repair function, rather go to device manager and uninstall the current driver by left clicking on the device and uninstalling it. After that, you will need to download the latest available driver for your current OS from the link below.
Click HERE to navigate to link.
Then reinstall the driver again.
If the problem still persists, you will ultimately have to reinstall your Operating system due to registry errors which causes the problem.
Try the driver installation, and let me know what happens.
Please feel free to let me know if you have any questions.
Kind Regards
Nov 13, 2011 | D-Link AirPlus XtremeG DWL-G520...
Does not show up on computer
I am assuming that you have run the install CD for the adapter, after which you are facing this issue. mentioned below are couple of steps which will help you to isolate the issue..
Please follow the mentioned step to check if the Wireless card is installed properly
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
Once you complete the above task you may follow the below mentioned step.
Following the below mentioned step will help the Microsoft to take control over the card and try to connect (instead of the software provided by the card manufacturer to control the device)
May 12, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
My d-link keeps disconnecting from the internet and will not reconnect or relaunch the wireless connection manager on vista.
I would try a few things. first go into control panel, system, then device manager. right click on you adapter and disable it for a few minutes. unplug the adapter and turn pc off. restart pc, wait a few minutes for every thing to boot back up, then plug the adapter in again. wait a few minutes. if this are not working still , go back into device manager and confirm it is enabled
Apr 29, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
Running winxp pro and installed d-link DWL-G122 adaptor. Everything OK for about 1 week. Now the adaptor will not show up in the "network connections" window but it does show up on device manager. the...
Uninstall any and all "Norton" application from your computer using the "Norton uninstaller". Then reinstall the network adapter drivers.
The norton firewall causes a HUGE LOT of problems to the network adapters.
Get another security solution, other than any "norton" product.
Nov 03, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Unable to instal d-link usb adapter dwa 110 for Windows Vista
hi,can any help me with the problem i have problem not play audio
Dec 19, 2008 | Compaq (243658-001) Wireless Adapter
Adapter stopped working
I have had a D-link wireless adaptor that has worked for years. I would say the device was faulty.
May 29, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Kensington (K33348) Bluetooth Wireless Adapter Logo
229 people viewed this question
Top Kensington Network & Wireless Adapters Experts
 C. Dante
C. Dante
Are you a Kensington Network and Wireless Adapter Expert? Answer questions, earn points and help others
