Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
Unplug the dryer. Remove the lint filter. Remove the 2 screws at the lint filter opening. Use a putty knife between the top lid and the front panel to release the clips. They are about 2 inches in from right and left sides where the top meets the front panel. Lift the lid towards the rear of the dryer. Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside. Place the new belt over the drum,ribbed side towards the drum. Look under the drum for the belt tensioner. It is S shaped with a wheel on it. Place the base of the tensioner in the slots below the motor pulley. Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel. Place this side of the belt over the motor pulley with the ribbed side touching the pulley. Replace the front panel. Hook up the door switch wires. Replace the panel screws. Reattach the top lid and lint filter screws. Replace the lint filter. Plug in the dryer.
the motor is humming,could be something stuck in blower wheel,might of had lint filter out and ran dryer and something went down into blower wheel,the belt could be locked up or the motor is bad,take the belt off of motor and see if motor spins
Model is 110.6705 Oasis Kenmore elite. Have removed back cover and have found drive belt broke. is there a seensor to shut motor dwn if belt breaks? Will order belt replace and see if thay resolves issue. Thanks
