Question about NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587)
  • 3 Answers
Try to check that the windows is allowed to control your wireless connection. Just go to control panel, wireless, and then configurations and see if the box for this is ticked..And dont forget to rate me if u like my solution. Trevor Smith
Posted on Nov 13, 2007
2 Suggested Answers
SOURCE: Can't connect Toshiba laptop to Linksys Wireless Routher!!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. your desktop computer can connect to the internet if u pull up a browser. First we need to access the setup page of the router by typing at the url of the browser:
2. it will show the setup page of the router. u can set the router on the specific internet setup that u have. since the router us setup already u have the internet connection thru the desktop computer using a wired connection..
3. Look for the wireless settings of the router and create first a ssid or wireless network name then u can as well set the wireless security by selecting wep, wpa, wpa2 then tkip.
4. once your done with the wireless settings, check now the settings for the toshiba laptop computer, some laptop wireless network adapter comes up with a software, I have a dell laptop and I dont use the software for the wireless adapter to connect to wireless, I disable it and use the wireless zero configuration of microsoft windows. u can check the wireless adapter software at the lower right corner of the taskbar, u can disable it by right clicking it and there will be an option to select to disable and sometimes there is an option as well to use the wireless zero config. given u already disable the software and there is no option to use the wireless zero config. u can click on start then run and type services.msc and the services tab will pop up and scroll down to the button of the services and u will see the wireless zero config, just right click on that line and enable it. once its enable it will show a wireless icon on the lower right of the task bar its like a little double computer icon, if it does not show, check on ur laptop maybe the wireless switch is off, the switch is located on the sides of the laptop or on the key area or check on ur manual on how to turn on the wireless switch if u cant locate it. once the icon show, right click it and select on view available wireless network and it will list all available network in range included the wireless network that u created, just select it and connect, then it will ask the password, type the password and connect. u should be connected.. I hope this will help u.. pls feel free to get in touch if u have any concern.
Posted on Aug 23, 2009
  • 94 Answers
SOURCE: Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default:
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Posted on Nov 28, 2009
0 characters
3 Points
Do I need any special equipment other than the ethernet cable connection for my linksys broadband wireless-g router
That's all you need to get your wireless internet up and running. However, in order to connect computers to the wireless network, they must be wireless capable, for example, most laptops have built in wifi, however desktops will need a wireless adapter to take advantage of your wireless router.
Mar 03, 2011 | Linksys Wireless-G Broadband Router
I have been told that there is no advantage in connecting to wireless broadband unless you are using a laptop computer.Is this so.
The speed of the internet the cable is faster than a wireless connection, the only advantage of wireless is that you don't have to run a cable to the computer to get internet. Hope it helps!
Mar 01, 2011 | Routers
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Just set up my g broadband router. Unable to connect to internet
Your laptop may not support g wireless. Change the wireless to broadcast B and G
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Where do I find the place for entering the WEP code on an additional laptop that is set up on wireless?
Step by step instructions on this address
Sep 30, 2008 | Dell TrueMobile 1184 Wireless Broadband...
My laptop stopped connecting to the internet
Is this the first time you've tried to connect you laptop?
Jul 22, 2008 | Linksys Wireless-G Broadband Router
NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587) Logo
35 people viewed this question
Top NetGear Routers Experts
Level 1 Expert
 Mike M
Mike M
Level 1 Expert
Are you a NetGear Router Expert? Answer questions, earn points and help others
