Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge spectra gas stove top not lighting
I have a GE Profile Spetra Gas oven/range that I inherited when I bought my house. I believe the stove was bought sometime in 2000. I can get the model if needed. When I tried to light the stove top the igniters click but the gas wouldn't flow right away. Initially it probably took 2-3 minutes to light. Then the problem started getting worse over time and now it probably takes 20 minutes to a half hour before the gas flows. Any ideas what would cause this? It's a natural gas stove and all the other natural gas appliances (fireplace, dryer) seem to work fine.
  • 2 more comments
  • rrolin Nov 24, 2007
    I have the same problem. Is there a delay that can be adjusted to fix this? So far mine seems to take 30 seconds for gas to flow and it doesn't matter which burner I light first. After the gas flows and the burner is lit, I can shut it off and immediately light any of the burners without delay.
  • bob279 Dec 13, 2007
    I was able to fix mine. All of the burners did act the same way. My problem turned out to be a bad pressure regulator. I replaced the service hose first, which didn't fix it, and then the regulator which solved the problem. Works like a charm now.
    What I believe was happening was the regulator wasn't holding a steady pressure of 4 inches of the water column. I was able to verify this by holding a match to the burner. After a couple mins it would light and the flame would look like it was on "simmer" when it really was on "high". Over then next several minutes the flame would grow to "high". To me that meant that the pressure inside the stove lines was gradually building up to the correct pressure.
  • erikK Dec 14, 2007
    I have the same problem with my Hotpoint gas stove. The top burners will take up to 20-30 seconds to light the first time. All of the burners will do the same thing. You can hear that there is no gas flowing. Then when the gas flows, it lights right away. I checked the plumbing and there is an individual valve for each burner. All valves are fed by the same pipe from the regulator. This tells me that there is little or no pressure in the line from the regulator. I am buying one now to fix the problem.
  • dolaahmed Jan 26, 2009
    I have the problem with my gas burner, it does not light. More specific is, it does not give the click click sound, which parts I should order? it's a maytag GAS burner. Do I need to order ignitor or spark something?
  • 833 Answers
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Posted on Dec 13, 2007
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove oven wont turn on
Put a new iginiter for the oven on your stove.
Mar 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas oven, stove works, but oven does not
the ignitor is bad. replace the ignitor and it will work perfect.
Feb 13, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
2,049 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
