Ahead Software Nero 7 Essentials Suite Full Version OEM  Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i edit a dvd? i copied a movie from tv but it ran over and dvd copied part of another movie.how do i remove it
Anonymous
Level 3:
  • Master 499 Answers
  • Posted on Jul 09, 2009
Anonymous
Master
Level 3:
Answers
499
Questions
Helped
193485
Points
1756
If u have recorded using dvd recorder then u need to use Pinnacle video maker or sony vegas to cut and edit ur movie
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Jul 24, 2009
Anonymous
Expert
Level 2:
Answers
74
Questions
Helped
11689
Points
169
Ok try doing the same thing again and press the record button from the remote and try it then from a vcr
2answers
Windows Movie Maker
try this ant use windows dvd macker to burdn you cd or dvd
tip
How to copy protected DVD on Windows?
DVD Copy is the useful software for us to backup our dvd, it can copy DVD perfectly at super fast speed. This DVD to DVD Copy can easily copy DVD in 1:1 ratio; compress DVD-9 to DVD-5, also can make the DVD backup to DVD folder or ISO image file, even burning DVD folders or ISO image files to DVD.
This best DVD Copy has more additinonal functions, like available for you to choosing copy full disc or main movie of the source DVD, select target audio and subtitle even include or skip menu to meet your specific need and edit the volume.
The powerful DVD Copy is a easy to use DVD copy and clone software. Without complicated setting, this DVD Copy gives you the total freedom to copy and backup all DVD movies to DVD disc in 1:1 ratio, or save DVD movies to hard drive as DVD Folder or ISO image file.
DVD Copy is the best partner for you to clone DVD to a new disc or copy dvd to DVD Folder, with the best DVD Copy, we can backup our favorite DVD easily with several simple steps, just have a try.
tip
How to remove iTunes DRM copy-protection and burn iTunes movie to DVD?
Many friends ask me how to burn iTunes movies to DVD, so that they can enjoy their movies on large screen TV. For computer newbie, I will recommend them to get an Apple TV; it can connect your iTunes library to TV, the only thing you need to do is to sync movies from iTunes to Apple TV box. An Apple TV costs $299, if you think this is beyond your budget, you can use software to do that same thing, which is a lot cheaper.
Now, let me explain the details. Because movies and TV shows purchased from iTunes store have DRM copy-protection, you have to remove the DRM protection before burning them to DVDs for playback on your home DVD player.
What you need are: Aimersoft DVD Creator & Tunebite. You can download them from:
http://www.topsreviews.com/dvd-creator/dvd-creator-aimersoft.html
http://www.dvd-video-converters.com/dvdvideosuite/backup-copy-protected-music-and-video-with-tunebite.html
Download Aimersoft DVD Creator
    Part1. How to remove DRM copy-protect from iTunes purchased movie or TV shows?
    Step1. Download and install Tunebite, just follow the installation wizard, this software will install several high-speed dubbings to speed up the conversion, when you see the pop up warning messages, just click “Keep on going” to finish the installation, which may take a few minutes.
    Step2. Then run Tunebite, click “Add” button to load your iTunes purchased movies or TV shows, the default directory is My Document\My Music\iTunes\iTunes Music
    In the “Convert Video to” drop down list, select “WMV7 (1024 kbps)”, then click “Start” to begin the conversion. If you don’t know where the converted videos are saved, you can click “Folder” to locate the files on your computer.
Tips: this software can also remove DRM from purchased music and audio books; it also works for other online stores such as Zune, Amazon, etc.
Part2. How to burn DRM-free iTunes video to DVD?
Step1. After you remove the DRM copy-protection from iTunes purchased movies, download Aimersoft DVD Creator and install it. (Note, you need a DVD Burner to burn DVD, so make sure your DVD Drive has DVD+RW or DVD-RW symbol)
Step2. Run Aimersoft DVD Creator, click “Load Video” button to import your DRM-free videos, and then drag the videos to the storyboard. If you want to burn videos to dual-layer DVD (DVD-9), at the bottom of the interface, select “DVD-R 9.0G”, you can also customize video quality there. And the used disc space is shown on the disc space bar underneath the storyboard.
Step3. If you just want to burn the video to DVD without adding any special effects, just click the “Burn” tab. Here you will see the following options:
“Burn to”: you can burn the video to DVD or create an ISO file on your hard drive.
“Drive”: If your computer has multiple DVD burners, you can select any of them.
“TV Standard”: NTSC is 30 fps. It’s used in USA, Canada and Japan. PAL is 25 fps and it’s used in Europe and Asia.
After the above steps, put a blank DVD disk into your drive and click “Start” to burn your movie.
Tip. You can use this software to add special effects to your videos and also create a DVD menu so you can use DVD remote control to control the playback.
Besides this you can also ues other softwares to help you to solve some related problems. I
have being used software called dvd burning
software
, which is easy to download and install, most of all ,its price is considerably
reasonable, if you are interested in it you can have a try. Best wishes for you! Of course you can have more choices for you, you can have a close look at best video editor to get more useful and
practical information for you!
on Jul 26, 2010 • Computers & Internet
1helpful
External Hard Drive
If you plan to store movies on the HD, better buying a 1TB hard drive. WD Mybook is one of the best external HD.
To rip and store DVD movies into the hard disk you will need a specific software, like the ones below.
DVD Converter - convert DVD video to AVI/MPEG/DIVX files
Freeware converts DVD AVI MPEG WMV RM to MP3 or iPod Video
Movie2x Freeware DVD Converter Download
DVDx (freeware from labDV)
2answers
Region codes reset
hi juferrer,i guess the dvd u have brought is from a foreign one. Region coding is how Hollywood studios stagger dvd movie releases across the planet. These codes ensure that one country doesn't get a DVD movie before the same movie is out in that country's theatres. In their corporate omniscience, movie studios have carved the planet into regions with each region having a specific code.
All DVD players and discs have region codes. A DVD player and disc must be of the same region or the disc will not play.
If you want to watch movies from other countries, you need a multiregion DVD player. This will allow you to play any disc from any region. However, because TV standards differ, you might need a specialized NTSC/SECAM/PAL TV or a DVD player that can output any signal to the standard your TV accepts.hope u get the point.
raj..
tip
Mac Blu-ray to iPad Converter - Best iPad Blu-ray Converter for Mac users Best...
Best iPad Video settings
Follow the optimal settings to get excellent playback quality.
Video:
Codec: H.264
Size: 640*480 or 1280*720
Bitrate: 2500kbps
Frame rate: 30fps
Audio:
Codec: aac
Sample rate: 48khz
Bitrate: 160kbps
Channels: Stereo
Pavtube Mac iPad Blu-ray Converter v2.6 is a powerful tool specially designed for Mac users to rip, convert, backup and edit both Blu-ray and DVD movies. The source movie could be from Blu-ray disc, DVD, Blu-ray and DVD folder, DVD ISO and IFO file. The ripper could remove all the protections of Blu-ray and DVD movies , back up the movies to hard drive, rip and convert them into other popular audio and video formats to playback on your beloved portable devices such as iPad, iPod, iPhone, Zune, Blackberry, PSP, Creative Zen, Xbox 360, Apple TV etc. Besides, the M2TS files can be imported to Blu-ray Ripper for Mac and converted to compatible formats for editing in video editing software like iMovie, FCP, Avid etc.
Blu Ray Ripper for Mac features powerful editing functions and customization. You can trim and crop the video to any size and any length, adjust the video effect, replace the original audio with your favorite music, add watermark to make your video different. More specific video and audio parameters such as frame rate, bitrate, sample rate, audio channel are available for your enjoyment as well.
The lastest updates improved the program to capture any of the Blu-ray subtitles and audio tracks. Even 7.1 channels is available. You may also back up the whole Blu-ray disc/ DVD to hard drive with one click.
What's new
- Added the option of one-click Full Disk Copy, enabling users to make 1:1 copy of Blu-ray disc and DVD.
- Added support for Blu-ray disc of MKB v17.
- Improved the loading speed of Blu-ray disc/ folder.
- Added customized output formats for iPad.
- Refine the GUI to be more user-friendly, and apply Deinterlacing facility by default.
For Windows user: Windows Blu-ray to iPad Converter
Learn more: Best iPad video conversion tools
on May 12, 2010 • Cell Phones
tip
on Feb 05, 2010 • Computers & Internet
Downloading videos to a dvd-r/rw
copy it to a folder under my document.
then
use the Windows movie maker to edit and burn the cd , free download from Microsoft.com .
or use the program that came with your dvd burner, like Nero or Roxio
How to make copies???????
Not sure whether you have a PC hardware or software problem. Do you have a DVD drive on your PC ? If you have, then this should work
1. Finalise the mini DVD on the DC210.
2. The mini DVD will have one folder on it called VIDEO_TS. Copy this folder to a new folder on your PC hard drive.
3. Put a writable DVD into your PC DVD drive.
4. Copy the folder you created in step 2 to your DVD.
Job finished !
If you want to edit the vieo content you'll need to get some video editing software.
Top Ahead Software Computers & Internet Experts
Alexander
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
