Hi !
I've a Broadband connection & I'm using HP pavilion laptop with Vista Home Premium as OS ..but I'm unable to open most of the sites. Only Google, orkut Gmail are opening...nothing else... not even Yahoo!...Search results in google too don't open... I always get the response "website found waiting for reply"
but when i use my friends laptop all sites open ...
Please Help me !!
[email protected]
Do you use a router, or are you connecting the modem straight to the laptop?
Does the modem have multiple plugs for computers to plug into (if so, it is functioning as a router as well.?
Do you have any firewall/internet security software installed?
My guess without the above information would be that it is a problem with your DNS setting. Open "Network Connections" and right click on your "Local area connection" and go to properties. Click on the "Internet Protocol (TCP/IP" entry and click properties. Be sure that it is set up to "Obtain DNS server address automatically"
From my experience with networking problems, Norton is often the culprit. First, try disabling all of the features of the Norton Internet Security, and see if that helps you at all. Even if it doesn't, that does not mean Norton isn't causing problems, With Norton "off" does not always mean it is completely "off".
If that does not work, try disabling norton by pressing WindowsKey+R to open the Run dialog. Enter msconfig in the run dialog and press enter. You will be working on the "Services" and "Startup" tabs of msconfig. Uncheck anything that looks like it relates to Norton on both of those tabs. It might be worth it to do a google search each Service name and Startup Item name to see what it relates to (for example, a program called ccapp relates to norton, but you would not know it).
Unchecking these items will simply disable them for now. You will want to remember or write down which items you have uncheck, as you may want to turn them back on again later. After you have uncheck all items relating to Norton, click ok, then restart your computer as directed, if your internet works fully now, that means your Norton Internet Security is causing problems, and I would recommend uninstalling it and finding something better.
I get th that exact same message when I click Properties on the IPv6. I beleive it is because IPv6 is not supported by the network card or it's drivers. Not usually a big deal unless you are using IPv6 for something.
My modem straight away connects to my Laptop.
No my modem is Not functioning as router.
I'm using Norton Internet Security 2007.
And when I checked the properties of "Internet Protocol TCP/IP" there are two internet Protocol ( Version 6 & Version 4)
when I clicked the properties of ver. 6 I got following message.." In Order to configure TCP/IP u will have to Install & enable a network adapter card !
and when I clicked ver. 4 properties all the settings were exactly the same as u adviced.
Please help me out.
What about TCP/IP version 6 why I'm getting that msg?
I wish you to help me create my website. I am in London. How do I pay? [email protected]
