Home | Epson | Perfection V100 Flatbed Scanner | Scanning photos
Epson Perfection  V100 Flatbed Scanner
Problem for Epson Perfection V100 Flatbed Scanner
Scanning photos
By misha1 on Nov 13, 2007
image is blurry and color streaks appear
Same Problem
Mar 21, 2009
-   I have the epson v100 and have had the same problems. I had the epson v1610 and got about 3000 scans out of it before it died. This scanner I only got less than 100 scans before having the same bars running down the scan. The problem did go away on its own for two weeks. Then started again. Spent hours with tech support. They are useless. Never buying an epson again. -   rzrnon 141
Dec 11, 2007
-   When scanning photos, I get stripes of color, red, yellow and green the length of the scan. These streaks are not on the original photos. The bed is clean. This scanner is less than a year old and has been used very little.
I am on XP Home.
I used an HP flatbed for over 5 years but had to purchase a new one because the HP was not compatible with XP. I chose this Epson flatbed scanner and at this point I am very disenchanted with this product!
Thank you for any help you can give me!!!!!-   Guest
Dec 05, 2007
-   Having the same issue. Strange streaks of color appear across the page. The bed itself is spotless and I've uninstalled and reinstalled the drivers and software numerous times. Spoke with Epson and they suggested I go to a service center for repairs. Hassle.-   JohnAA
Solution #1
posted on Mar 04, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i just had my CCD replaced before my warranty expired in Feb and it worked fine for a week. Now i'm getting a cyan line down all my negative scans. And since you can only scan negatives in one spot, I can't even use a diff part of the scanning surface to avoid this. Sounds like a downright cheap part and definitely can't do the job. Never buying an Epson again, esp since they closed down the repair center nearby.
Popular Solutions for Epson Perfection V100 Flatbed
Questions and Unsolved Problems for Epson Perfection V100 Flatbed
Do you recommend Epson Perfection V100 Flatbed Scanner?
Answer
Answer
how to scan a document into pdf using epson perfection v100 scanner? i push the pdf button, nothing... (More)
Answer
When I scan a large image using the whole face of the scanner, it leaves a stretched/blurry stripe... (More)
Answer
After the Espon V100 scans the photo it says: Unable to write the file. Help! :)
Answer
I am getting banding down each page (wide vertical streaks).
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Perfection V100 Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 699
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
