The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
Unplug the washing machine's cord from the electrical outlet.
Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5
Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6
Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7
Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8
Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
- Phillips-head screwdriver
- Putty knife
- Nut driver
- Needle-nose pliers
- Timer
Warning
- Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
knobs on that machine just pull straight off. No clips or retainers.
