Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Electronic buttons not working
Have to push many times to get response
I need to repair my Franklin electronic dictionary.
I would try replacing the unit's battery. If that does not work, it sounds like you will have to replace it. It should be cheaper to replace if necessary than to repair.
Aug 23, 2016 | Franklin Office Equipment & Supplies
Nikon ML-L3 remote control working d7100
Set the camera to one of the remote modes. The quick-response remote mode fires the camera when you push the button on the remote, just as if you were pushing the shutter release button on the camera. The delayed response remote mode gives you two seconds to hide the remote behind your back before firing the camera. The remote mirror-up mode raises the mirror the first time you press the button, then fires the camera the second time to prevent camera shake.
See "Remote Control Photography" beginning on page 127 of the manual: http://download3.nikonimglib.com/archive1/jx33T00TFfqq00nXNhJ55CBmTl26/D7100_NT(En)03.pdf
Jan 29, 2014 | Nikon ML-L3 Remote Control
Mac power light flashes 3 times, no usb response
Push the power button and wait for 10 seconds.
Jan 24, 2018 | Apple Computers & Internet
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
My Kenmore Elite washer model 110.27062600 stopped working. All the front panel lights are flashing on and off for 7 times then pauses and starts blinking again. The machine will not do anything. No...
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Sep 19, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
No start no stop of my teadmill t9600 but the other buttons areok
The buttons on this unit are on an overlay. Basically, the buttons are a big sticker that goes on the console. I would start by checking the connection between the overlay and the console board. If the connections in good, then try a new overlay. If that does not work then the console board is bad.
Mar 22, 2010 | Dmm Vision Fitness T9500 Treadmill
My wife was beginning an auto cleaning of our whirlpool range oven [model RF387LXG]. When changing the automatic cleaning time from the 3 hr 30 minute default time to 2 hr 30 minutes, the display began...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%#$^YRGD
Dec 24, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Dell x50v won't turn on
while pushing the power button , push reset button for couple of seconds. hope that helps as that is what worked with mine.
Jun 11, 2009 | Dell Axim X50v Pocket PC
2007 Nissan Versa gear shift locked in Park. My Versa will not shift out of park unless i push the shift lock button. What could be the problem?
There is a switch under your break padal, which is responsible for tail lights and gear lock. if that switch is working fine and your tail lights are working fine then check the electronic lock of gear which is under the cover of gear.
Mar 12, 2009 | 2007 Nissan Versa 1.8 Sl Hatchback
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
132 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
