Question about Compaq Armada 1590DMT Notebook
Adding wireless to Compaq Armada 1590DMT laptop
Is there anyway I can get wireless for my Compaq Armada 1590DMT laptop? I have an ethernet card, but I keep breaking the adapter that fits on the card.
  • 85 Answers
Re: Adding wireless to Compaq Armada 1590DMT laptop - Compaq Armada 1590DMT Notebook PC Laptops
USB wireless
Posted on Nov 13, 2007
0 characters
3 Points
I have an older model armada 7800 that I am trying to get connected to the internet. Where does the ethernet cable go on this model? The only place I see for it is in the back, but the cable does not fit...
It may not have a place for an Ethernet cable. These older laptops required special cards to be attached to them or inserted into a special port for them to work with an Ethernet cable. The port your referring to might be for a phone cable which means it would have a modem and be dial-up only.
Oct 28, 2010 | Compaq Armada 7800 Notebook
I don't remember keys for enter in to bios Compaq Armada 1590DT
Remove the bios battery and put it back and it will not request password from you anymore.
You go to the manufacturer for them to reset it for you.
Aug 19, 2010 | Compaq Armada 1590DMT Notebook
How can I boot to usb using compaq armada?
after pressing the on/off button immediately keep on tapping F12 and the boot menu will appear on your screen, just select the USB and press enter
Jun 12, 2010 | Compaq Armada 1590DMT Notebook
AC Adapter
It should have the power cord as according to this page courtesy of HP:
They don't show a part number for the ac adaptor though which in normal circumstances you should get that to when you buy it straight thru HP but they may be out of them.
You can find one off of ebay and it does exist as according to this auction:
So definitely you can get one from Ebay if all else fails. Hope this helps you.
May 18, 2009 | Compaq Armada 1590DMT Notebook
Make a compaq armada 7400 wireless
you would need to install a pcmcia wireless card.
Mar 01, 2009 | Compaq Armada 7400 Notebook
Can the Compaq Armada E500 go wireless?
any laptop has the capability to use wireless connection, if you connect to that laptop a compatible wireless card and install its drivers( the cd/dvd that comes with the wireless card)
to check if this card is ok or not try using it on some other laptop see if it works there and gets the networks
further Queries are welcome
Feb 18, 2009 | Compaq Armada E500 Notebook
Armada M700 & Linux XP 2006
Yes I used the latest version of Ubuntu Linux.
Get it here
Ubuntu 8.10
You will need to install NDIS in linux after the install to use the windows drivers for your wireless card if you have one. Sometimes older wireless cards will work but most of the time you need the NDIS to use the windows disk that comes with your wireless device(if you are using one) Your hard wired ethernet port should be detected automatically as well as all your other drivers(since the machine is old)
Good luck..if you need any more help I will be around. No other compatibility issues exist, and it will run a lot faster than XP. I would suggest 512MB of Ram but 256 will handle it fine.
Oct 14, 2008 | Compaq Armada M700 Notebook
Compaq armada 1580DMT
Sound's like you've had a hsrd drive crash. The message 32768 kb ok is a memory test, this indicates that something went wrong with the operating system the last time it was shut down. It should, after the memory test, either correct the system problem or give an error code. Since it does nothing, this indicates that the hard drive has failed and, unfortunately, needs to be replaced.
Jun 20, 2008 | Compaq Armada 1590DMT Notebook
Grahics in limited colours
The video driver is the 2nd one:
or here:
Feb 16, 2008 | Compaq Armada 1590DMT Notebook
When you reset your computer you need to click the Del button , or one of the "F" buttons
Aug 06, 2007 | Compaq Armada 1590DMT Notebook
Compaq Armada 1590DMT Notebook Logo
153 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
