Question about Sharp LL-172CB (Black) 17 in. Flat Panel LCD Monitor
LL-172CB, 17'LCD monitor
There is not power for my LCD monitor, no power LED on front of the monitor, I checked the fuses and i found them Ok, i inspected the internal power supply for any burned component but every thing looks in good condition, my power cord is fine and i don't know what else i can check.
Any suggestion.
Thanks
Edgar Paco.
  • Manson007 Sep 17, 2008
    I have my LCD (sharp) bought in year 2004 not working.
    First of all, the power button was not working. I could turn on and off my pc thrugh the PC on/off. I could not turn on/off my LCD as I used to.
    A few days later, now the entire LCD is off by itself. I have no clue. I need an answer for that.
    Thanks
    Noah
antiochpc
  • 1314 Answers
SOURCE: LCD monitor very dark.
The most likely cause for this problem is the backlight in the LCD. Over time, this light gets dim causing the problem you describe. I have never actually replaced a backlight myself. With the price of monitors these days, even if I could find one I don't think it would be worth my time and money to replace. But if you want to take the chance, try finding a monitor with a cracked LCD on ebay or look at the back of your LCD screen after you remove it from the monitor and see if someone is selling a used one somewhere by searching for the model number of the LCD screen.
Posted on Jun 10, 2007
  • 1019 Answers
SOURCE: lcd monitor will not stay on
First thing to try, is to check the cable from Monitor To PC Or Graphics Card.
If you have a loose-broken internal wire, this will be the problem. Dry-Solder Joint et,c.
If the cable, has a socket either end, from monitor to computer.
try to obtain a replacement cable. The second option is to test the output source. i.e Graphics card or output to the monitor.
Hope this helps Mike @ Compurepair.
Posted on Sep 16, 2008
rylee_smith
  • 8619 Answers
SOURCE: I need to find drivers
Hi
Thanks for using FixYa. You can download its drivers by clicking on any of these two links:
Sharp LL T17A4-B Drivers
Sharp LL T17A4-B Drivers-2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Mar 08, 2010
rommelalilin
  • 2178 Answers
SOURCE: How can I open the case of a Sharp LL 172A-B 17"
Gently pull the frame off because they have lock latches.
Posted on Nov 11, 2010
Testimonial: "Thanks for encouraging me to keep trying to separate the outer plastic case. Eventually I succeeded, but I still could not get at the backlight."
No power in monitor
First check for a LED indicator? if there is one is it changing when you turn on your monitor? if there is changing light then the problem might be on the power supply or maybe on the LCD lamp. To check the power supply check for a defective fuse a defective fuse has no reading on multimeter and the o.k has 000 reading. the LCD lamp power supply can be converted into different power supply. hope this may help you.
Jul 27, 2011 | LG Flatron L1750S 17" LCD Monitor
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
My Sharp monitor172CB is missing part of the
Sounds like the back lights are burned up. That will make it difficult to see. There are videos to show you how to replace them. But I don't know you expertise.
Jan 13, 2018 | Sharp LL-172CB (Black) 17 in. Flat Panel...
BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem - Power LED Blinks
Look for small power transistors 2SC5707 near yellow invertor transformers which go to backlight connectors.
But if problem is blinking power LED powersupply capacitors maybe an issue,check visualy and/or replacement.
Also fuse that maybe blown is not glass fuse near mains socket,It is semiconductor black or yellow colour labeled PFxxx near heatsinks of power supply secondary.
Please rate the solution and provide feedback.
Samir
May 25, 2008 | BenQ FP767 17" LCD Monitor
Blank Screen, power light is steady green
have you tried adjusting for the brightness and contrast of the monitor. does any menu comes out if you press any buttons of the monitor except power of course!
Nov 16, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
Aug 15, 2007 | Neovo AG 17" LCD Monitor
No power in dell e173fpf
I would expect the same (new) part failed. Try another dual diode otherwise you may be chasing the problem around the board.. Good Luck, Tim
Feb 19, 2007 | Dell E173FP 17" LCD Monitor
Sharp LL-172CB (Black) 17 in. Flat Panel LCD Monitor Logo
43 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
