Sata as boot and install eide drive as d:or e:
I have win xp on a sata drive as my boot drive and want to install my old eide drive for extra storage.i have a cd player as d:,how do i install the eide drive ?
    Scholar:
  • 86 Answers
You can slave the EIDE hard drive off of the CD Drive, as long has it is also EIDE. There should be a flat grey ribbon cable plugged into the back of your CD Drive. That IDE ribbon cable should have 2 connectors on it, one of them should be plugged into the CD Drive.
If it does not have 2 connectors, then go buy a new IDE ribbon cable that has 2 connectors, they are cheap. Or ask a friend, he/she might have extra, I always do.
Make sure you have the jumper settings correct on both drives. One will be the master, the other should be the slave. Or set both to "select select" and let the computer decide. The jumper is a little black jumper that connects 2 pins together on back of the drive. This tells the drive if it is a master, slave or cable select.
There should be a sticker diagram on each drive denoting the correct pin-jumper setting.
One other thing, when you hook up 2 drives to 1 IDE cable, both drives share the bandwidth. If you are using one of the drives, don't try to use the other, major performance slow-down.
Also, you don't need to slave the drive. You can get a Hard drive enclosure and make the drive an external drive connected by USB. They are also cheap, but make sure the hard drive has a partition and is formatted before installing it in the enclosure.
http://www.geeks.com/details.asp?invtid=COSMOS-525U2-SIL&cat=HDD
Posted on Nov 13, 2007
Canot change win 7 to xp
XP has probably not got the SATA drivers required to find the drive. It is too old.
Have you initialised the new hdd?
Mar 06, 2015 | Gateway M Computers & Internet
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Feb 22, 2010 | Computers & Internet
A1430N Moved my two working ide drive 250G over
Hello
Thank you for using
FixYa for your problem
IDE will try to boot first when pluged in, sata will not boot. I think there is a adjustment in the BIOS setting to have the SATA boot first
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Apr 16, 2009 | ASUS P5LD2-VM Motherboard
Ms-7061 msi motherboard will not install win xp with sata drive
The problem is that your version of XP does not have SATA drivers and therefore does not recognise your new drive. Vista does. If you Google the problem you will find many solutions on how to rectify the situation. Basically, you have to make a floppy disc with the correct drivers for your Motherboard's hard drive controller. Then, when you launch your Windows XP installer, it will ask you a question about needing to install 3rd party drivers. Yes is your answer. Tap F6 to ensure that the installer doesn't skip.Insert the floppy disc and then after the drivers are loaded, the installation will proceded normally. The other alternative is to leave your existing XP installation in place and add the new disc. Later you can clone your old disc onto the new drive and then remove your original disc.
Feb 11, 2009 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Recognize sata hd
No drivers are needed - it should have been seen right away. Check the BIOS to see the drive is seen in the drives tables, and if there, XP needs to have the drive setup using FDISK. The drive will not show under windows until a drive table is on it.
Sep 05, 2008 | Intel Motherboard
Windows XP SP2, Intel DG965WH mobo. Two SATA hard drives, two EIDE hard drives (WD200EB). Suddenly one day, without warning, the two EIDE drives just disappeared from the Hard Disk Drive list and files...
the problem sounds like you either lost the IDE channels on the MOBO or the chipset was updated with corrupt files.
run everest home and see if there are current updates for the northbridge chipset. if you have 2 ide channels on the board switch the primary and secondary ribbons and see if the hard drives are there. if your cdrom's are ide and after switching ribbon cables they disappear and the hard drives reappear your mobo lost an ide channel, you would need to replace the board.
Aug 01, 2008 | Computers & Internet
Drivers
http://www.eid.toshiba.com/support/swdrivers.shtml
Oct 16, 2007 | Mysoftware MyMailList & AddressBook...
SATA won't work
I think you're saying you've got XP installed, but the second drive isn't showing up.
You need to format the drive.
Right-click My Computer/Manage/Disk Management.
The drive should show as unallocated. Right click and select format. It may ask you to create a partition first.
Oct 16, 2007 | Intel Motherboard
Computers & Internet Logo
400 people viewed this question
David Payne
David Payne
