Question about GE JKP15 Electric Single Oven
Built in GE wall oven
I have the same problem with trying to remove the front panel on my GE wall oven. No matter what I did I couldn't get the front panel off! I took out every screw I could find, tried to push it up, etc. The touchpanel has a metal border all the way around it that will not budge.
  • Mr Cranny Jun 14, 2008
    I have the JKP27G0H1BG oven and the timer is shot so I bought a new unit. There are two screws which take allen wrenches on top of the control panel and phillips head screws in the middle of the oven. The control panel comes away from the wall but I don't want to break anything trying to pull away the control panel to install the new timer unit. The GE hotline is useless. Any thoughts? Am I missing a hidden screw?
  • Anonymous Jul 01, 2008
    Can't get the control panel off to check connections et al (F 7 digital error message displayed) on our Kenmore Elite Double Wall (electric) Oven.
    model #911.49033100.
    For a minute...looked like your site would have an answer to the two other people who asked similar questions...but we can't find your answer ...if there is one. please advise today...we're strapped & need to do the repair ourselves. The panel is loose & seems to be hanging from the top what we don't know.
I have a GE wall oven and the light bulb has burned out. I can't get the cover off to see what size bulb I need. The model number appears to be JkP20BOF1BB.
Posted on Jan 22, 2009
  • 1,314 Answers
Why are you trying to remove the panel are you talkin about the control panel
Posted on Dec 29, 2007
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
We needed to change out the change out the main board in our GE monogram wall oven due to the dreaded periodic flashing of the display boards. We had a hard time getting the panel off the oven, until we unscrewed the oven from where it is secured to the opening in the cabinet for the oven (4 screws). We also unscrewed the 3 screws under the panel (hex head). Once the oven was pulled out slightly, the panel lifted up easily. We took a picture of how the main board was plugged in, before removing it. Unplug all the harnesses, some have a clip that you may have to gently pry to loosen. There are 2 black clips on the front edge & 5 white/yellow plastic anchors that hold the board in. Squeeze the tab on the anchors to loosen them & carefully pry the clips to remove the board. After installing & turning the power back on, we got some crazy setup info on the text display board; we turned the power back off, waited a few min., turned it back on & it was good to go. I hope this helps someone. I find looking stuff up & finding the answers to be usually helpful, but couldn't find the answer to this.
Posted on May 11, 2013
There are to Torx head screws on the top and bottom of the Control panel cover. You need to remove all four and then take the black handle of the Self Cleaning lock lever. It come off, put you have work at it.
Posted on Sep 08, 2008
  • Al1950 Sep 08, 2008
    There are two Torx head screws on the top and bottom of the control panel cover. Once the four screws are out, you need to get the black handle off the Self Cleaning lock handle. It will come off, just work at it. (typed the last response in a hurry)
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Wall Oven JKP30W0M1WW - front control panel overlay bubbles and separates. It did this before it was 1 yr old and they sent me a replacement and now before that part is 1 yr old it is doing it again -...
GE is now fixing this problem, no charge. I called about mine, at 866-622-6184 They have the white version already available. A month wait on the black. Then they send out a service tech to install, free to you.
Jul 20, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
After doing a self clean, the panel now flashes locked
thermal protector has caused lockout. happens w/ self clean a lot. it's a small thermostat device most likely on the rear of the oven. oven need to be pulled from wall to check/replace. you may have to open door w/a coat hanger if it's locked to get the door open to allow access to screws to allow removal of oven from wall if it's a built in. unplug it before doing anything. fuse is under back cover size of a bottle cap, 2 wires, should be "closed" normally. replace or spray w/freon to "reset" it.
May 25, 2009 | GE Profile 30" Built-In Single Electric...
Special GE wrench to remove front panel
You need a safety screwdriver or a safety wrench, you can find the tool at Stanley's, call them and tell them your appliance model number if you are not sure what tool to buy.
Feb 07, 2009 | GE Ovens
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
GE JKP15 Electric Single Oven Logo
1,386 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
