Could be the photocell (CAD cell) on a residential boiler, or a fuel problem ie dirty fuel filter, oil lines losing prime.
Thanks Todd i appreciate your time ,i ,changed the filter that solved that problem
now another problem arose, my house has 3 zones, the finished basement, the main floor, and the floor above that,all the pipes going to the baseboards get hot, im getting heat from the baseboards in the basement and the floor above the main floor, but no heat coming from the baseboards on the main floor .like I said the pipes going to the baseboards are hot.if you or anyone else have any suggestions they would be greatly appreciated. thanks again. .
SOURCE: LOW WATER CUTOFF IS CHATTERING ON WEIL MCLAIN
Don't jumper that control out. You likely have some thing going on with the make up water. best i can do with information provided. T
SOURCE: weil mclain heII-4 short cycles burner comes on
Make sure the exhaust fan is pushing out hot air and not obtstructed. Check the pilot assembly, clean ane make sure the sensor is well into the flame. Watch the flame to see if all burners are igniting. If not, clean the burners and the flame tray that spreads the flame to all of them. Look for a sensor at the farthest burner and make sure the probe is free of carbon and the wiring is tight.
SOURCE: We ran out of oil. I have a 6 month old Weil
Hi, I have nothing in front of me to tell me what these codes are saying. If it is only 6 months old, do you still have the manual on this unit? If so, it should tell you in the trouble-shooting section on what might happen when it runs out of fuel oil. If not, I know on gas fired heaters I can reset the codes by turning off the power supply for a few minutes and reset the codes that way. If you haven't done this you might give it a try. If this does not work, get back to me as I will look for information on this model to see what I can come up with. If killing the power works, please keep me posted.
Sincerely, Shastalaker7
SOURCE: My Rheem furnace fires up but the fire keeps cutting
Hi check out the pressure switch ,jump it out see if it fires clean flame senser if fitted, clean airfilter check fan afc is clean might be dusty
Testimonial: "Thanks for the suggestions, a service like this at 1 am is great."
SOURCE: How tough is it to install a new tankless coil in
There will be a screw or nut that holds the whole control in place. The probe is very short. When changing the coil, make sure you have a clean surface on the boiler where the new gasket will mate. You can use some high temperature silicon to hold the gasket in place but just use a minimal amount. Too much and as you tighten the bolts, it will push out the new gasket. Before attempting to loosen the bolts, spray them with penetrating oil a day prior to the repair. An impact wrench will quickly loosen the bolts if you can use one.
