Question about Brother DCP-7020 All-In-One Laser Printer
Lcd sceen is scrambled
I can't read anything on the screen, is there anything I can do or do I have to live with the problem?
  • 4,402 Answers
Re: Lcd sceen is scrambled
Have you tried to unplug it and plug it back in?
Posted on Dec 20, 2007
0 characters
3 Points
The LCD display screen is blank, back-light remains on. Powering off machine to power back on results in loud, abrasive rattle which seems to come from scanner. Unable to do anything with device.
When this happens the first thing you should do is check the connections to the LCD screen. However if it was working fine before this is most likely not necessary since they have to be connected properly to show anything. After that you would need to replace the LCD or the Logic board. If everything else is working properly then the problem is more than likely the LCD needs to be replaced.
Mar 12, 2014 | Brother MFC 6490CW InkJet Printer
My ricoh ft4530 control panel does not display anything and no light when turn ON. Power is OK
1st try the adjustment knob on left side of control panel. still nothing it could be a bad lcd screen or power board to the lcd screen
Apr 16, 2010 | Ricoh FT5832 Copier
HP 7410 will not boot. It powers up and the HP logo appears on the screen with a progress bar. The display then scrambles and the power light flashes green. No buttons work or do anything.
connect the printer directly to the wall socket for the power supply if it is connected thrugh surge protector.
perform a reset :
unplug the power cable .
press and hold # and 6 key on the printer..
plug in the cable wait for 20 secs then release the buttons..
after this the printer will re-initialize .. this may take few mins..
and chek after that
Oct 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Scrambled then black lcd panel... help
Does the printer still function properly besides that issue?
Go to the web interface and look at the real time display on the webserver, If it is displaying correctly, you will need to replace the LCD
Jun 23, 2009 | Xerox Phaser 7400/DXF Laser Printer
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Oct 26, 2008 | Printers & Copiers
LCD Screen
my screen is completely black but sumtimes it lights up for a sec. dunno wut to do
Sep 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
48 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
