Question about RCA 36V550T 36" TV
  • 1 more comment
  • ron63 Nov 18, 2007
    Seems like the same problem. Just started 2 days ago (11/16/07). Neither remote nor main power button will turn on the tv. Test showed that power is making it to the tv. Is there a reset procedure for the 36v550t?
  • Anonymous Dec 28, 2007
    The only thing I can determine is the relay mage by Goodsky keeps tripping the power on and off. I have tryed to find a Goodsky relay in the USA with no luck. Still looking. I think Allied Electronics has a #821-1028 that should work but I am not sure. Anybody know where to get a Goodsky relay in the USA?
  • Anonymous Jul 06, 2008
    tv wont turn on
    Problem Solver:
  • 13 Answers
Put batteries in the remote
Posted on Jan 22, 2008
Rca media streaming player won't turn off or on with remote
Don't worry mine's a piece of **** too. When I have that problem I just unplug it and plug it back in a few times and eventually it will turn on by itself when you plug it in. And by then the remote usually starts working. If not then I suggest pushing down on your battery while holding the remote pointed STRAIGHT AT the box. That usually does the trick even though its a HUGE pain in the ***.
May 06, 2012 | RCA DSB772WE Wi-Fi Streaming Media...
Why is my tv cutting on an off
If it is a RCA 36V550T do you hear a high pitched sound from set before you try to turn it on?
The model indicated is well known for the High Voltage transformer and or a sweep transistor failing.
The transistor is easy to check with a ohm meter and if shorted 100% chance it and the transformer are both bad (usually just the two parts)
Mar 26, 2012 | RCA 36V550T 36" TV
Trying to figuire out if the RCA 36V550T is Digital or analog?
That's a CRT... it's inherently analog. If you use the right equip, you could get a digital signal to display on it, but the picture would still be analog.
Aug 09, 2011 | RCA 36V550T 36" TV
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
36" RCA TV Wont power up
IP030 Regulator part number 263567/ Regulator overheating
Nov 29, 2007 | Televison & Video
Samsung TXN2726 Televison Remote
hiya sounds like the remote has de-registerd it self with the telly. all you need to do is find out the infered codes for that telly and do the [set] - [TV]combo with the numbers after.
Oct 02, 2007 | RCA 36V550T 36" TV
NEED HELP !!!!! remote will not work (original nor directv programed)
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Sep 14, 2007 | RCA 36V550T 36" TV
RCA 36V550T 36" TV Logo
272 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
