Question about Panasonic TC-32LX60 32 in. LCD Television
No power but has red light flashing
I have a tc-32le60 that does not turn on but flashes a red light i checked all the fuses inside all are fine. any suggestions?
  • 3 more comments
  • Brownwiz Jul 15, 2008
    Same Problem
  • Anonymous Jul 23, 2008
    I have the same problem. The power will not come on. I unplugged the TV, replugged it and no luck. It flashes two times, and then pause and then two more, on and on...
  • miss1278 Jan 25, 2009
    Im so impressed with this site lately! It has really been helpful! I had the same problem with my tv and holding the power button for 60 seconds really worked! It sounded crazy, but it saved me alot of money!
    Thanks for the tip!
  • thescriven Jun 19, 2013
    known issue with Panasonic call tem they will send a software update flash drive
    I have the same tv, it's a known issue with this brand of Panasonic. call them and they will send you a sd card with software update. I just got it and haven't installed yet.
Thank God for the internet. I had the same problem and I googled it and found this site with this solution. It worked fine. Thank you. Like you said, unplug, hold the power button for 60 seconds and replug and turn on. Worked like a charm. Thanks a bunch.
Posted on Feb 15, 2010
I've had the same problem for the past two months, but after unplugging and replugging a couple of time it would start working again. I talked to tech service and they recommended I unplugg, then press and hold the power button on top the tv for 60 seconds. Then replug and should work. His claim was that it would reset some power circuitry, although it seemed odd to me with the power being unplugged. However, I haven't had the problem for a couple of days now. We'll see.
Posted on Aug 25, 2008
  • cindyor Aug 02, 2011
    I had the same problem after coming back from vacation. This worked! Yea! I called Panasonic and they were no help at all.
Holding the power button for 60 seconds unplugged worked for me too!!!!!! very happy about this site! good stuff.
Posted on Sep 24, 2008
I have a tc-32le60 that does not turn on but flashes a red light i were are the fuses located. any suggestions?
Posted on Feb 24, 2008
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
TV power loss
most likely the part inside the tv has gone bad as you said that you heard a pop and this lead to take the tv to a technician.
Apr 29, 2008 | Televison & Video
Is the Panasonic TC-P42C2 supposed to have a flashing red light that suggests which board is the problem? If there is no red light, what does it suggest?
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 20, 2014 | Panasonic Televison & Video
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
I forgot my unlock code
Check the user manual. They usually have a key sequence to unlock it.
Apr 29, 2010 | Panasonic TC-32LE60 32 in. LCD Television
I can`t get the screen to go to the entire width of the tv on high definition channels
check to see if you have a format button on your remote , or a zoon button . usually thats the case.
Feb 25, 2010 | Panasonic TC-32LE60 32 in. LCD Television
Where to get LCD screen for panasonic TC-32LE60 TV ?
Hi there, the only close part you could get is the actual cabinet. the actual screen will have to be shipped by the manufacture itself. these screens are filled with a liquid that is dangerous and has to be installed in a OSHA approved shop.
Feb 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Oct 23, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Red Light Flashing 6 times
A 6 blink usually indicates a bad thermal fuse caused by the lamp temperature getting too hot. I strongly suggest replacing the sirrocco fan that mounts on top of the optical block too. Usually this fan gets clogged up with dust so the lamp temperature gets hotter than it should causing the thermal fuse to open up. Replacing the thermal fuse, sirrocco fan and cleaning the dust from the inside and fans will cure this. A Sony authorized servicer should be able to repair this for you. Good Luck
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
Panasonic TC-32LX60 32 in. LCD Television Logo
2,067 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
