Question about HP PSC 750 All-In-One InkJet Printer
Printing without color
I ran out of color ink but what I wanted to print needed to be in black won't let me print without color being in it. I tried taking it out and it wouldn't I put it back in and it still won't print. Do they both need to be full in order to do any printing??? Any help is appreciated greatly!!
  • 1 more comment
  • CWITTEMAN Apr 09, 2008
    I also would like to be able to print using only black ink cartridge. Is there any way to change the settings to print in black and white only and not have the printer shut down because the color ink cartridge is low/needs replacing?
  • gukevi Apr 20, 2008
    how come the hp psc 750 uses colour to print in a mac pc even though the page is in black texts? The setting doesn't have black/white printing, only grayscale and colours. And the printer uses colour to print black texts too, when it should really use the black cartridge. Seems to be fine in windows operating system though.
  • Anonymous May 03, 2009
    There is really no solution to this. HP has designed these printers to work only when there is sufficient ink detected in all cartridges. These guys make a lot of the money out of consumables - that is why they will give you the printer cheap because they know how to milk you. That's the reason that all the manufacturers make their own cartridges which are not compatible with other manufacturers. The printer consumable business is a gold mine for these guys and they know how to fleece their customers!!
Each cartridge must have a certain amount of ink for the machine to run, even though you only want to print in black and white. Hope this helps.
Posted on Apr 11, 2008
SOURCE: Black ink stopped printing
Did you solve this problem, the exact same thing has happened with mine?!?
Posted on Mar 11, 2008
  • 4 Answers
SOURCE: canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Posted on Mar 06, 2009
SOURCE: scanned pictures are printing with different colors
Are the ink cartridges refilled or compatible? They may be defective.
Are they installed correctly (not in the wrong slots)?
** Note that even if they are replaced it will take SEVERAL pages before the quality returns
Posted on Mar 11, 2009
  • 111 Answers
SOURCE: colored ink not printing correctly, lots of lines
You can try to use an other cartridge. if that won't fix your problem, you should send the printer back for repair
Posted on Apr 21, 2010
  • 7 Answers
SOURCE: ink full printing black great but the colors arnt
Use the Power Purge Function to bleed the line and clear any clog... Make Sure have more ink on hand...
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Posted on Jun 04, 2011
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
My printer keeps wasting my color ink
The best answer is for you to buy a laser printer rather than inkjet. The laser printer will print at a lesser cost per page than the inkjet, and the color issue will be resolved
Sep 06, 2009 | HP PSC 1510 All-In-One InkJet Printer
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Ink Cartridge Settings
Have you tried Canons FAQ? They suggest checking the grayscale box, which apparently only works with certain kinds of printing (duplexing and borderless will still use colors). I don't understand how colored inks are used to create black, but that's what they claim. Anyway, here's the link:
Jan 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printing in black & white when color cartridge ran out
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP PSC 750 All-In-One InkJet Printer Logo
190 people viewed this question
Ben Johnson
