Lands Phones Logo
A
Anonymous Posted on Mar 15, 2015
Why can't I hear incoming callers on my BTVERVE 410. The handset display displays SILENCE
1helpful
INCOMING CALLS SHOW "601 DAY" ON THE PANASONIC KX-T7630, THE CALL DISPLAY IS GONE, HOW DO I FIX THIS?
Next time you have an incoming call:
-Leave the handset down (do not answer the call).
-Press the 'transfer' button to scroll through the different displays until the caller ID is shown.
-Lift the handset to answer the call.
-The next time you have an incoming call it should show the caller ID.
4answers
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
All incoming calls say Private
Hi Helen,
Try disabling caller display. Prove that you have managed it and then enable it
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Display incoming call icd
As long as this setting is on the lines and if analogue lines a caller I'd card is installed, press TRANSFER while the handset is ringing to change the display
1helpful
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
1helpful
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
2answers
I have a Panasonic KX-TCA132E but no instructions. I have set up with my phone company for incoming caller id to be displayed, however it is not working. Do i have to use the handset to activate the...
I have had this phone (twin) for quite a few years . If your incoming line supports caller ID it should work immediately. I never had to activate this. I would check if caller ID on your line is working. Check with another phone if you can.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
