Question about Microsoft Xbox 360 Console
Xbox 360 dashboard 2.0.17150.0 can't reset family settings
  • Shane Daniels
    Shane Daniels Sep 10, 2016
    I don't know how get through my family sittings please help 2.0.17150.0
  • Shane Daniels
SOURCE:
SOURCE: xbox 360 family timer
Try Unplugging it for an hour or so (like how power outages ask you to set up your console) and ask him if he knows it...
or de attaching the HDD :) it's removable you know!
so much power for a little kid :(
Posted on Feb 25, 2008
scanss2k
  • 166 Answers
SOURCE: xbox 360 password recovery
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
Hope that helps
Scanss2k
Posted on Aug 21, 2008
SOURCE: reset family setting password
Here's what you need to do:
Turn on your xbox, go to System Settings. From there go to Console Settings. A window should appear that asks you for your password. If you don't know your password, then make up something. It will tell you your password is incorrect, click Reset Password".
You'll need to type in: YrYa
If this fails, then you need to follow these steps to reset your factory settings.
Turn off your xbox. Take your hard drive out (the bulge on the side of your 360. It says HDD on it.) by pressing the gray button, and sliding the piece out. Turn on your xbox, go to System Settings - Console Settings - System Info.
Press these buttons IN ORDER:
LT RT X Y LB RB Y (using the left joystick) go right ONCE A
After all of this is completed, a window should appear asking you if you would like to reset your system settings, press yes!
After all of this is completed, you'll need to turn your xbox off, put the hard drive back in, and turn it back on.
I JUST had this problem, and this is what tech told me to do... and it worked.
Good luck! Down with passwords!
Posted on Feb 19, 2009
benwabnick
  • 2404 Answers
SOURCE: Cannot remember my Xbox 360's passcode and reset answer!
Try these steps first:
Go into settings .... console settings...then device settings or the blue screen then go...
left trigger
right trigger
x
y
left bumper
right bumper
left with left stick
up with left stick
right with left stick
x
If that doesn't work then call 1-800-4MYXBOX they will walk you through it.
Posted on Jul 04, 2009
Mykel_N
  • 315 Answers
SOURCE: Forgot password to unlock family settings on xbox 360?
I've managed to come across this from someone who called microsoft with the same problem (it seems quite common)
Go into settings Console settings Then device settings (The one with the blue screen)
Then go:
left trigger, right trigger, x, y, left bumper, right bumper,
left with left stick, up with left stick, right with left stick, x
If you have trouble use the pad instead of stick, but I could only get the stick to work..
I hope that helps
Regards
Mike
Posted on May 27, 2010
How do I remove a parental lock plz on xbox 360 if I don't know the code. It was on when I bought it.
You can give this a shot....
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
This should bring up a menu
Reset System Settings
Resetting your system settingswill return all console settings tofactory defaults.
Do you want to
reset to factory defaults?
Yes, reset settings
your screen should go blank for about 2 seconds then the language blade should appear that lists several different languages,select your preferred language then a blade that says "Xbox 360 Storage Device" should appear
With the options of
1)
Done
2)
Continue without one
s
elect to Continue without a profile
Then an Initial Setup Complete screen should appear with the options of
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on
Parental Control lock should be disabled
Sep 30, 2015 | Video Game Consoles & Games
How to reset xbox family code?
If you can use the dashboard then you can reset to factory defaults from the system settings, if you can't log on at all then resort to xbox support for more options.
Jul 28, 2014 | Microsoft Xbox 360 Elite Console
How do you reset the family settings for xbox 360 dashboard 2.0.16747.0?
Reset Family Settings (Factory Reset) for Dashboard 2.0.16747.0
System -> Console Settings -> System Info (Press "A")
LEFT TRIGGER (LT), RIGHT TRIGGER (RT), X, Y, LEFT BUMPER (LB), RIGHT BUMPER (RB), Down, Down, Up, X,
Apr 23, 2014 | Video Game Consoles & Games
I forgot my family settings pass code and reset code for the xbox 360
Reset a Forgotten Pass Code To reset your Family Settings pass code after you've forgotten it:
  1. From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
  2. Enter an incorrect pass code.
  3. You will be told that your pass code is incorrect. Select Reset pass code.
  4. You will then be shown your pass-code question and asked to answer it.
    Type your answer using the on-screen virtual keyboard and either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console. Your answer is case-sensitive and must be typed exactly as you entered it originally. This will clear your original pass code and allow you to enter another.
Jul 20, 2011 | Video Game Consoles & Games
My xbox 360 has a passcode that have been set but i do not set the passcode.
Repeat the Set a Family Settings Pass Code procedure, beginning with step 2.
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jun 12, 2011 | Microsoft Xbox 360 Console
I bought my xbox 360 from a buddy a few years back and my brother as of recent has been an *** and i want to set a passcode of the 360 itself so he cant use the xbox live without the code. and there...
Hope that helps, best of luck.
May 24, 2011 | Microsoft Xbox 360 Console
I dont remember my family passcode.and im trying to figure out how to reset it
Many people have asked how they can reset the family timer settings and/or the passcode on their Xbox 360 console . I have the answer! No cheap tricks! Reset all passcodes and security questions with this code: 1. On the 360 dashboard, scroll over to the "System" tab. 2. On the System tab, click "Console Settings". 3. Scroll down in console settings and click "System Info". 4. When the system info box comes up type in this sequence: LT RT X Y LB RB Y "Left Stick in" (press it in) Y Y A box should come up and say, "Would you like to reset the console to the factory defaults?" Click Reset and you're done! If this doesn't work, and that's highly unlikely, call Microsoft at 1-800-4MY-XBOX (U.S.). Provide them with your registration info and they will tell you how to reset the console. or, CallXbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Dec 13, 2010 | Microsoft Xbox 360 Console
Dont know password
if that is a password for the xbox live passcode, the passcode being asked everytime you sign in, the password is the password itself when you try to recover your gamertag
if that is a passcode for watching videos, or something.
that is a family settings passcode, the only way to override that is to call tech support, give the console serial number of your xbox of course, the serial number has a unique reset code attached to it..
tech support will give you some things to press on sytem info page of the dashboard to reset the family settings
Jul 02, 2009 | Microsoft Xbox 360 Console
Cant remember parental control code.
All Details Below On How To.
restart 360 Unit
press
factory defaults. Do you want to
Yes, reset settings
No, don't reset settings
select to reset settings
With the options of,
Done
select to Continue without a profile
with the options of,
Family Settings
Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
Jun 25, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
1,897 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
