Question about Kenmore 24 in. 17032 Built-in Dishwasher
Dishwasher 665.17033403 Gentlemen: Please to send electrico diagram, to dishwasher, model 665.17033403. Thanks.Roberto AyalaKenmore
5 Suggested Answers
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore 665 Dishwasher Not Draining
After the first try of our dishwasher the water didn't completely drain. Ever since the same level of water hasn't drained from the dishwasher.
Posted on Jun 17, 2008
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Posted on Apr 08, 2009
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
Posted on Mar 27, 2010
0 characters
1 Points
I have a fridgediere dishwasher and I took the top shelf out to clean the dishwasher now I can't seem to remember how to get it back in. Can you help me?
I could look up and post a diagram for your dishwasher if I had the model number.
Also see this tip.
How to receive the best dishwasher repair help on FixYa
Please let me know what the model number of your dishwasher is, thanks.
Aug 03, 2011 | Dishwashers
After removing the bottom assembly from my frigidaire dishwasher to clean it, I reassembled it and now the spray arm won't work although the machine fills and drains. I found a small white ball in the...
The ball goes under item 10 this picture:
You can enlarge the picture once opened. The Expert Gene Strote was correct. I just like this picture better because you can instantly expand it with explorer.
Manual Number 5995477345.pdf is a service manual not for your unit but will show you the sump and were the ball goes. (registration required)
A service manual that will show you the sump area and the ball.
Thanks for choosing FixYa, and myself.
Jul 30, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Is the above dishwasher a hot or cold fill machine?
not able to see what the above dishwasher is please send the make and model number although mostly all dishwashers have cold water tht goes into the machine and a heater on the bottom of the machine heats the water if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | Dishwashers
I own a bosch dishwasher model SHU33AO6UC and the problem is that water comes at the bottom although the machine is off
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at-
Aug 04, 2010 | Dishwashers
Bosch dishwasher noisy vibration
Jun 06, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Danby countertop dishwasher DDW396W pump size???????????
Best place for Danby parts is Sears Parts department online. Type in your model number DDW396W. They have diagrams and assessable and parts for just about everything you need.!retrieve.pd?modelNumber=DDW396W&pop=flush
Just click on the sub components area that you need!
Jun 25, 2009 | Danby 22 in. DDW396 Free-standing...
Bosch dishwasher
hi there,
just sent the diagram off to you.
please let me know when you get it.
Oct 07, 2008 | Dishwashers
Go to and type in your model number as "587.712403". This omits the space you had between the last 6 numbers. There are helpful exploded view parts illustrations available for every section of your dishwasher, including the lower pump and motor assemblies. In addition, if you require replacement parts, the part numbers are also provided. I hope this helps you.
Sep 04, 2008 | Dishwashers
Control Panel
There is a pic with the buttons in there.
Aug 13, 2008 | Siemens 24 in. SL84A305UC Built-in...
Dishwasher is leaving food particles everywhere
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. Hope this helps, APP tech
Aug 03, 2006 | Admiral 24 in. DWUA800AA Built-in...
Kenmore 24 in. 17032 Built-in Dishwasher Logo
131 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
