Question about Heavy Machinery
Calculate the weight of the complete load - show all calculations. The load to be moved consists of drums stacked on a pallet - 12 to a layer (each drum is 20kg) Three (3) layers on the pallet. The pallet is standard size and weighs 40kg. What is the combined weight of the drums and the pallet?
    New Friend:
1 Layer = 12 drums
1 pallet = 3 layers
1 drum = 20 kg
1 pallet = 40 kg
3 layer w/pallet = (12 * 3 * 20) + 40
= 720 + 40
3 layer w/pallet = 760 kg
Posted on Jan 04, 2017
SOURCE:
A cereal box have a length of 12 1/, weight of 10 and a height of 22
There is no question here?
To calculate volume, you need height, depth and width. Weight is dependent on the density of the items inside the box. For instance Rice Crispies are a lot lighter that ball bearings or Salt.
Aug 18, 2017 | Cars & Trucks
1 tonne of wheat will fit into how many cubic metres
There is no direct conversion for this because one unit is weight the other is volume, and i also depends on how much and if its compacted or loosely filled. You can do an experiment and calculate it yourself. Get a box and measure the L, W, and H in inches of the inside of the box, and weigh it empty. Then fill the box with the wheat (as loose or as tight as you think it will be in the silo). Once its filled level with the top edge, weight it again. Then use this formula to calculate the volume in cubic feet: V = (L x W x H)/1728 and subtract the total weight from the empty weight to get the weight of the wheat. If the total volume is say 1.47 cubic feet and the weight is 9.0 lbs. Use these values to calculate the totals your looking for, just convert them to metric before you do the calculation.
Mar 05, 2015 | Office Equipment & Supplies
I have a pallet 1 m x 1.2 m how many cubic meters will i use to fit this in?
All you have given are measures to calculate an area. You need some value for a height.
Aug 29, 2014 | Office Equipment & Supplies
How to calculate yield % of: a carrots weight
Divide 2.20 by 2.50, then multiply by 100.
Aug 21, 2013 | Office Equipment & Supplies
How to calculate how many months in 970days?
Divide 970 by 365 to get 2.657 which is 2 years and some.
Calculate 970-2x365=240 days.
Divide 240 by 30 days to get 8 months.
Total is about 24+8=32 months.
You can also calculate the average length of a month as 365/12=30.416666666
Then calculate 970/(365/12)=970x12/365=31.89041096 or about 32 months. Or 31 months and 27 days.
May 30, 2011 | Casio FX-9750GPlus Calculator
Conversion of log base 10 to log base 2
To calculate the log base 2 of a value, calculate its log and then divide by the log of 2. You can use either the log or the ln keys, but be consistent. For example, to calculate the log base 2 of 16, you can calculate either log(16)/log(2) or ln(16)/ln(2).
Nov 27, 2010 | Casio FX570MS Scientific Calculator
ERR12 AND16 KEEP COMMING UP NEW SCALES unable to reset
Err 12 Inital load is too high power on zero point outside permissible range
Err 16 No zero point available, unable to calculate weight
Check no load on platform
Check the sensor this could be defective. This is the most likely
Sep 02, 2010 | Seca 354 Digital Baby Scale Pediatric...
Heavy Machinery Logo
1,524 people viewed this question
Top Heavy Machinery Experts
 steve
steve
ray gallant
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
