clock can be corrected at the bios like when it boots go to the bios and set it there, but my hunch is that though you have tried this,you are getting it changed every often to a default date of manufacture this generally happens when the battery on the motherboard has gone weak resulting in inaccurate time and also sometimes loosing bios settings too best way to correct it is to change the battery on the motherboard
in the taskbar you can find the clock at the right bottom corner of your window screen double click that the clock screen will open you can change the time with that
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
a Old Hard drive had fell on the Case of the computer(fell really on Power supply ) then wen i...
(More)
a Old Hard drive had fell on the Case of the computer(fell really on Power supply ) then wen i picked up the hard drive i noticed that Pc was off tried 2 cut it back on with no luck.. it will start and u will hear everything boot up but nothing on screen so i replaced the power supply and gotten a new monitor but still no luck.. the keyboard light wont even come on..... i have tried using the on bored video still no luck....... Wen I took out the ram the fans will start up but there will be no beeps
I think my onboard video card not working on asus pss800 vm because I get a NO SIGNAL when turned...
(More)
I think my onboard video card not working on asus pss800 vm because I get a NO SIGNAL when turned on.
