Question about Samsung Digimax S630 Digital Camera
Card Locked? Don't know how it happened but when I try to take a picture a message comes up CARD LOCKED. How do I unlock it?
  • 75 Answers
There is a switch in the memory card, you just have to slide it upward.
If you are using a new memory card, format it first.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Select Format
- Select Yes
Posted on Nov 30, 2007
The memory card is locked! I don't know how this happened but I want to delete the photos. How do I unlock the card and delete all the photos
Depending on the card, there may be a little slide lock on the side that you can move with your thumb to lock and unlock.
Aug 23, 2011 | Cameras
My camara always show a message Card locked What do I have to do to delete that message
Since you don't know how it happened, you should read the manual, to see what LOCKED is.
Go through the setup menus and find the place where you lock and unlock the memory, because it probably thinks you have write protected some of you images.
Maybe you should take it out and put it back in again.
Take out the batteries for a day or so, to let the thing reset.
Re-format the card, after saving everything of course.
Aug 01, 2011 | HP Photosmart M420 Digital Camera
I have a Canon G10. When I removed and reinserted my sdhc card, I now get a message that the card is locked. This happens for every card I now insert, even though the lock switch is in the unlock...
Some canons have a switch inside the card slot....don't know if you can get at it but you can try things like a dental pick, a toothpick, etc. Be careful.
Jun 25, 2011 | Canon PowerShot G10 Digital Camera
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
Card locked
If this happened after the card had been removed then you may have inadvertently slide the card lock into the 'lock' position. If the card has not been disturbed, the very fragile 'switch' may be defective. I would try removing the card and operating the slide-lock several times and then leaving it in the unlocked position.
Jun 18, 2010 | Canon Cameras
Card Locked! Message on Samsung l313
Go into the setup menu and do a camera "reset".
Sep 07, 2009 | Samsung Digimax S500 Digital Camera
Casio Exilim EX-S880 how to unlock card
hello, check your card for a clip and see if its in lock position. set it to unlock.
also check if your card is compatible for you cam.
Mar 24, 2009 | Casio Exilim EX-S880 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Card locked
Reformat card - have you tried? Check your manual seek help in Samsung Web site Come back if still int rouble
May 06, 2007 | Samsung Digimax 4010 Digital Camera
Samsung Digimax S630 Digital Camera Logo
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
