Question about Insignia IS-DVD1001 DVD Recorder/VCR
Camcorder Widescreen Recording Issue
I have an Insignia dvd/vcr combo (not sure of the model - don't have instruction book handy) and am having trouble getting it to properly record onto a dvd from my Canon camcorder. The camcorder is set to record a wide screen image. When I plug the camcorder directly into my standard tv, the image comes out in letter box like I'd expect. My camcorder is set to display it's widescreen image in a letterbox format on standard tv's.
However, when I plug the camera into the Insignia dvd/vcr, the widescreen image is streched vertically so everything and everyone is too tall and skinny (my wife likes the effect, actually). The image recorded on the dvd looks the same - all streched out. The dvd/vcr is also set to display widesreen images in a letterbox format on my tv, and when playing rented or purchased dvd's, the do display in letterbox. It just seems to be a problem with how my widescreen camcorder image is translating through my dvd/vcr.
  • 1,003 Answers
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Posted on Feb 02, 2008
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Lost instructions, cannot create DVD from cam-corder recording
Thanks, I already solved the problem. There was no "Setup" button (on the remote, anyway) to follow the instructions given -- in the manual, which I downloaded!.
Instead, I remembered that "Input" often allows you to select a source for something, so when I chose THAT button, I was able to choose the port that had my cam-corder.
Then I simply pressed record on the DVD player while Play on the C-C.
Mark H.
Dec 15, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Cannot timer record with Insignia HD TV and LG DVR/VCR
Make sure when you do the process two things: one, a blank tape or If it is a dvd recorder, a blank disk is inserted, in the tape make sure the tab that prevents recording is not broken.Two, before exit the timer recording menu, make sure that there is not a instruction that says "done" or "confirm" or any word meaning that all the steps went through.
Nov 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Please check page-14 of user manual of Funai MWD2205 VCR/DVD Combo for recording in VCR from Camera or some thing else as external source.
Here you can download User Manual for your unit, in case you dont have it.
Need further help, let me know and post here.
Thank you.
Oct 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Recording problem
I would suggest using the manual,you can download one,just type in name and model+manual ,to google
Jul 16, 2008 | GoVideo Go Video DVD/VCR Combo
Toshiba D VR660KU DVD VCR combo
The unit will only allow 2 hour recording on the DVD+R format. The DVD-R format is adjustable for longer recording time, just understand that the longer recording times = the lower the quality of the recording.
Jun 01, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Dish Pro record code for Mag combo
ZNREL, I've done this with Dish Pro before. Setup the Dish remote to control the Mag combo in the VCR position. Press the SAT button and select the guide. Go to the program in the guide and select it. The "record this program" routine should pop up, set it up. Here's the key, make sure the Dish remote has the VCR button selected and that the remote is placed where it can "see" the Mag combo. At the set time, the Dish remote will change the DishPro to the proper channel and then issue s "record" command via infrared to the Mag combo to start recording. DishNet has all of the device codes to their remotes downloadable from their site.
Mar 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
• AV2: Audio/Video Input mounted on front
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
103 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
