Question about Keurig Elite B40 Coffee Maker
WIll not brew
All the lights work fine, put in water, put in K-Cup ... "ready" light comes on, press the "Brew" button .... nothing happens.
Could this be the thermal sensor, or something else?
  • 11 more comments
  • Kinderdine Mar 16, 2008
    Same problem
  • knowcoffee Jun 29, 2008
    Power light lit. Put in Kcup. Close lid. Green brew light flashes. Press button. Green light goes out. Nothing happens.
  • mich1983 Jul 01, 2008
    I have the same problem can you help me?
  • ALMLHOLLIS Jul 26, 2008
    SAME PROBLEM AS OTHERS. PWR LIGHT ON, INSTALL K-CUP, SHUT LID, PRESS BUTTON THAT IS FLASHING. LIGHT GOES OUT AND NOTHING HAPPENS. OPEN LID AND REPEAT SAME PROCEDURE.
  • kaycousins Aug 14, 2008
    lights working. water resouvoir full. Will not brew coffee. I've pressed flashing light several times.... after that it will fill cup to overflow occassionally. more often, it just won't brew.
  • jackie85 Nov 19, 2008
    I am having a problem with water not coming through the pump. So therefore. no coffee
  • crusnik Dec 17, 2008
    same deal.
  • yougefe Dec 21, 2008
    keurig b40 will not pump water
  • needscoffee Feb 01, 2009
    I have "de-scaled" often, the water is filled, the lights are on, we have a go.......but push the large cup option and nothing happens - This is not good as we are both standing net to the machine with bed head, looking forward to that first sip.  Any help out there?   Needcoffee in Philadelphia
  • crusnik Feb 02, 2009
    same deal.
  • needcupojoe Feb 08, 2009
    I have the same problem...All systems are go but when I press the brew button it it sounds like it starts but then quickly stops. It has gotten progressively worse over the last week or so....it would take a few tries and then work but now nothing!! This coffee maker is only a year and a half old.
  • firstlady08 Feb 15, 2009
    I have the same problem, the water reservoir is full of water and it heats up the water but when i put in the pack of coffee and push the large cup button, it makes a sound like it is gonna work but nothing happens except a little bit of coffee (drops) will go into the cup. PLEASE HELP I need my coffee. If any help please contact me at mayorofbock@yahoo.com
  • Anonymous May 06, 2009
    Lights come on, water is full, but when I hit the small cup, nothing happens. No sounds or anything! HELP!!
  • 5 Answers
Try this, worked for me:
Just today we've found that at the first water intake (on my B60, that's where the water container plugs into the base) on the base is a little circle valve type thing. That's where the water gets sucked out of the tank. Shine a flashlight into that circle, and you'll see a screen type thing there. It's like the screen in your faucet when you unscrew the tip and there are little rocks and stuff in it? Same principle: there were cotton fibers and other assorted weird stuff clogging that screen. Used a toothpick or a needle and removed all the debris from the screen, and it now works perfectly!
Posted on Feb 18, 2010
Keurig has a customer service center that you can call. The technicians there will help you with almost any problem you have. That number is 1-866-901-2739. Most problems are caused by blockage in the needles. You have to clean both the one in the k-cup holder and the top lid area. A tooth pick works great for that. Good luck.
Posted on Jun 05, 2009
    Problem Solver:
  • 15 Answers
You probably have an open check valve, using to strong a vinegar solution for cleaning eats away at the glue holding the check valve together, as a result you are sucking air, take the bottom off, pull out the check valve, apply a little super glue and you are golden, alternatively you could purchase a new check valve. I fixed mine this morning.
Posted on Jun 28, 2009
I have the same problem, my b40 will not brew
Posted on Jul 01, 2008
Mine had the same problem. Everything looked and worked fine until I pressed the brew button and it would make it's normal sound for about 2 or 3 seconds and then stop, with a few drops of coffee falling into the cup. I took a pin and cleaned out the top pin that pierces the K-cup, and it worked fine again. It must have been clogged. Hope this helps.
Posted on Jan 21, 2010
Have you found an answer to your no water problem? Still waiting for that first cup this morning - send help fast!  Thanks - needscoffee
Posted on Feb 01, 2009
Why did our keurig b70 just quit working?
Try unplugging it for 30 sec. and plug back in. Give it time to reset. Hope this helps
Feb 05, 2018 | Keurig Platinum B70 Coffee Maker
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
Will not brew . says ready to brew but when I press brew button nothing happens
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101]][[]
Aug 19, 2011 | Keurig Ultra In Home Single Cup Brewer...
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
Platinum B70 sometimes won't brew
I also have the same problem. Is there a pattern here?
Jun 11, 2010 | Keurig Platinum B70 Coffee Maker
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
How do you turn on a Keurig to get a cup of coffee - I hit the button and it says green and ready but nothing is coming out - I put the cup's worth of water in the side container - what do I do to get it...
I know on mine I have to open and close the chamber where I put my coffee. It then blinks ready and I press the size cup I want to brew. Hope this helps! :) And sometimes if there isn't enough water in the reservoir it won't brew so try and putting more than just a cup's worth of water in it :)
Sep 12, 2009 | Keurig B50 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
1,716 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
