Same philosophy regardless of vehicle or equipment.
CAUTION! Battery contains acid which can also be present in general area. Take appropriate precautions.
1) Dis-connect Negative terminal.
2) Disconnect Positive terminal.
3) Remove battery hold down brackets
4) Remove battery from vehicle. Rinse hands to make sure no acid on them
5) Clean terminal connections (battery post clamps). I use a weak solution of baking soda in water and soak the clamps until the foaming stops, then rinse well with fresh water. It's a good idea to rinse the battery tray with the baking soda solution and then water before installing the new battery.
6) Place the new battery in the correct position in the vehicle.
7) Re-install the hold down brackets.
8) Connect the positive cable to the positive battery terminal.
9) Connect the negative cable to the Negative battery terminal.
10) Start engine to check.
11) All done, Make sure the hood is closed.
12) Nap time.
