Question about RCA TruFlat 27F520T 27" TV
Watching tv and screen goes black w/no more sound!
It's like it had a heart attack or something....
I was watching my RCA 27 TruFlat TV this weekend and all of a sudden the screen just goes black, the sound dies and now I got no more TV. The quotes I've gotten from repair places are $150+. The TV is only about 4 years old, but it's been in the shop before (not for this though). Could it just be a fuse? Could I fix this myself?
Thanks in advance, JS
  • jjsankwalker Nov 14, 2007
    what is a tester? where would i find the fuses to check? thank you for your response!
  • Anonymous Dec 13, 2007
    I have an rca tv the screen went black and there is on sound
  • 749 Answers
You can check only for the fuse if it is busted or not
locate the fuse. check if it open using a tester.......
if you have no experience yet on electronic servicing then you can fix it.
Posted on Nov 14, 2007
Rca truflat model# 27F520TYX1 IT HAS A black screen with sound
Check its Line Output Transformer {LOT}. Repalce it.
Apr 23, 2012 | RCA TruFlat 27F520T 27" TV
When watching a movie, on the bottom left of the screen is discolored. like on the blue screen, its lime green
This problem only happens when there is something magnetic in by the tv where the screen is lime green. Good luck!!!! hope this little bit of info helps
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
My RCA TruFlat 27F520T 27" TV started acting up.
The buttons on the tv are the problem. I clipped the prongs on one of mine and fixed it .Just use the remote now
Dec 28, 2010 | RCA TruFlat 27F520T 27" TV
Picture went off on rca flat screen while watching still have sou
That probably happened because something hit the TV and broke the line for pictures to get through, or because a wire in you TV is bad and doesn't wanna work. This happened to my TV every few days. What I did is give it a few whacks every now and then on top of it and the vision came back, but don't try that if you think your TV is fragile. Yes I know its sounds stereotypical but it actually sometimes works.
Well, good luck!
Jun 04, 2009 | RCA TruFlat 27F520T 27" TV
My 27" truflat RCA tv, which is 4 yrs old, went blank
Hi,you will need a soldering iron and a voltage needle so you can test the Ic components on the main board. you will need to test the transistors as well. once you find the bad parts, you will have to order them and remove the bad parts and replace them with the ordered parts by using the iron and solder. this issue will be located on the input side of the main board. you should notice it by the discolorations on the board. (truama poitns)
Mar 13, 2009 | RCA TruFlat 27F520T 27" TV
Rca truflat 27"
You can take off the back of the tv. Look for the red wire at the top of the tube. Follow it down to the part that it goes into. On that part (transformer) there are 2 controlls. The one marked SCREEN, is the one you can turn up and watch the screen at the same time. If the tv shuts off, put that control back to the original position. If it brings up the brightness, then it is fixed. If not, take to a repair shop.
Jun 13, 2008 | RCA TruFlat 27F520T 27" TV
Rca standard defintion truflat
the power supply is main cause problem of tv,you coldsolder the main board of your tv.
May 04, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat TV
You may have a loose solder connection on the circuit board inside your set.
You need to have a technician check it for you.
Stargazer
Jan 16, 2008 | RCA 27F530T 27" TV
RCA TruFlat  27F520T 27" TV Logo
144 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
