I have a Dyson ball and when I turn the power on there is noise, the brush rotates, however there is no suction.
This could help you:
http://www.fixya.com/support/t2827418-very_little_suction_in_hose_no_tears_in
It worked for us.
The only thing i know about vacs is if there is no suction its blocked might have sucked up a piece of plastic bag and wraped around the fan hence no air or the screw that holds the fan has come loose take your filters out and turn on you may have sucked up fluid and not known it hence filters are blocked also brushes may seem alright but may be worn under half there fore springs are not at right tentsion if your armiture is black where the brushes run on may not be getting a good contact or if it smells burnt good chance you burnt it out then theres the power switch test with multi tester the check for loose terminals then test the field coils are correct ohms as well
