Question about Brother IntelliFAX 4100 Laser Fax
Number of rings before pickup
I would like to change the number of rings to 1.
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
How to pick the call from other extensions
I have downloaded several manuals for the Avaya by searching online, some are good basic user guides and some very technical. You can pick up a call in several different ways - here is a copy from the manual on call pick ups:
2.2.2 Call Pickup
If you hear another phone ringing, there are a number of ways that you can answer the call if you know the user, group
or line being called.
1.If already on a call, end the call by pressing Drop or put it on hold by either pressing Hold or pressing the
button which the call is on.
2.Press an idle Intercom or Call Appearance button.
· To pickup a call ringing at a particular extension:
Dial 6 followed by the extension number at which the call is ringing or parked.
· To pickup the longest waiting call in a pickup group:
Dial 66 followed by the pickup group number (1 to 4).
· To pickup the call ringing on a particular line:
Dial 68 followed by the two digit line number.
3. You can continue the call handsfree or switch to using the handset or headset (press the HEADSET button).
To Create a Call Pickup Button (ETR 18D/ETR 34D Phone)
1.At the phone press Feature 00.
2.Program Extension: is shown on the display.
3.Press the button that you want to edit or enter a number between 03 to 80 to select a button. The current setting
of the button is displayed.
4.Press the first intercom or call appearance button.
5.Dial 6 followed by the target extension number.
6.The button function is changed to Call Pickup followed by the target extension number.
· Exit programming by pressing Feature 00. You can also exit programming mode by lifting the handset, then
placing it back in the cradle.
To Use a Call Pickup Button
1.Press the Call Pickup programmed button
May 29, 2014 | Avaya Corded Phone avaparp18d
Cannot change the number of rings before answer pick up
Enter the model of your VTech 5.8GHz system into the search box at to download a copy of the manual.
Feb 28, 2014 | Vtech 5.8GHz Analog Cordless Phone
Group Pickup setup on Strata 280 phone system
Try Googling (Toshiba)(280)(manual) without parens.
Aug 12, 2017 | Toshiba Computers & Internet
Setting the ring pickup of panasonic fax
This has to be done in the service mode.
monitor key slowly 4 times
scroll down to number of rings
clear 2 times
May 28, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
Need to reset the number of rings before fax pickup on 2 hp offi
default ring is 5.
if need to change the ring, then you will be in maual answer mode.
better choice is to change the ring on the phone and the answer machine.
Dec 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
How do you answer another phone in the office by using your own phone
Ascertain from your system administrator the directed call pickup feature access code, this will allow you to pickup any ringing call as long as you know what ext number is ringing.
Jul 11, 2008 | Mitel 5220 IP Phone
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
Feb 14, 2008 | Uniden Cordless Phone
Change dial-times before pickup
Press fuction 7/ monitor 4 times slowly/ press */ press 3. Wait for printout. Do the above only press 1 as last step, enter the number to change whatever this parameter/ press set/ stop/ stop
May 23, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Brother IntelliFAX 4100 Laser Fax Logo
56 people viewed this question
James Cagle
James Cagle
Jim Keysor
