Question about MSI KM2M Combo-L (MS-6738-010) Motherboard
Shuts down 5 to 10 sec after start up
I turn the power on it turns on and starts to boot up then the screen comes on and then it shuts down i cant fig. it out i have been trying for days
  • 121 Answers
Re: shuts down 5 to 10 sec after start up
First of all get to the jumper next to the cmos battery in the main board try to change its position for some seconds while power is off this way you will clear cmos. start computer go to bios (hit delete on start up) and save changes.
hit delete on start up and load system defaults then exit saving changes.
chek the board position sometimes if its bottom was in contact with any metal of the pc case then this could cause it to restart (this could damage ur system too!)
Posted on Nov 13, 2007
0 characters
3 Points
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Aug 07, 2013 | Motherboards
Asus will not turn off after shutdown
All these things point to the bios. You need to go to the Asus site for that motherboard and download an upgraded bios. There will be directions there on how to update your bios, probably both from Windows and from the system prompt.
Apr 19, 2012 | ASUS P5AD2-E Deluxe Motherboard
Problem with ASUS P5GD1 mobo
Try taken the bios battery out for about 30 secs, replace it and then reboot, after post press F8 untill you have a screen pop up with a safe mode option use the arrows keys to navigate to safe mode and press enter. In safe mode goto my conputer c:drive(boot drive) windows. In the windows folder look for a file called prefetch, delete all it contents. Exit out of everything and restart the pc. If same thing happens post back.
Feb 05, 2010 | ASUS P5GD1-VM Motherboard
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
first thing to do is unplug the machine, hold the power button in for 20 sec. after unplugging it, then remove the disc battery you should see in the mother board, keep it out for 60 sec. then replace it plug it back in nad reboot it. lets start from there and get back with me and please don't forget to rank this solution and if I can be of any other help let me know. Have a wonderfull day and thank you for using
Mar 05, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Start up of m2n-mx
Do you hear any beeping when it boots up also the Asus board has a boot up software that checks the motherboard and its components. Let me know what it does or says.
Nov 13, 2008 | ASUS M2N-MX Motherboard
Keeps turning off
Sounds like a hardware failure. Possilbly the motherboard, more than likely, the power supply.
But then - maybe neither.
Shut it off completely, once you restart, start hitting the F8 key ( once a second ) until you see the " Safe Mode" choices screen. Drop down and select the " Last known Good Configuration" option and hit enter.
If this doesnt work, try the same proceedures ( restart - F8 ) but this time select safe mode - at the top of the list.
If you sucessfully boot in safe mode, you have a system file problem that could be virus related, file table corruptions or registry problems or all combined.
We're here if you need us.
Oct 10, 2008 | MSI PT880 Neo FSR Motherboard
Compaq nx9105 windows wont boot up
use xp disk and perform a repair
Oct 29, 2007 | Intel Motherboard
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
MSI KM2M Combo-L (MS-6738-010) Motherboard Logo
173 people viewed this question
Top MSI Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a MSI Motherboard Expert? Answer questions, earn points and help others
