Question about Toshiba RD-XS34 DVD Player/HDD Recorder
Hi, I just connected my toshiba recorder to my tv, I turn them on, and I cant see any menus on the tv's screen, it doesnt play any of the hard drives files...
It runs, it works but it doesnt display nothing on the tv.
I TV cable from wall to recorder and from recorder to tv, I can see the TV programs but not the DVD or hardrives ones.
  • yo1974 Nov 21, 2007
    Thank you man, that was it....
  • andrewt71 Dec 04, 2008
    I have a RD-XS34 and I am unable to view the TV guide menu. It worked fine initially and for a while, but now I'm getting a grey box over the TV Guide area. Everything else works fine, but I can't do a whole lot without the TV Guide menu. Any help would be greatly appreciated.
  • 67 Answers
You MUST connect the recorder to the Tv with a SCART cable that is why you are not seeing anything.
I suspect you are using only the RF or Ariel Cables
If you have it connected with the scart cable you must choose the AV channel on your TV remote.
Posted on Nov 13, 2007
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
When i am recording from television and i turn television off the dvd appears to be recording but there is a blank screen when i check it to play
are you using AV jack to connect the recorder with TV for recording porpuse. if it's correct then it's simple, if recorder not gate inpute signal from TV, then it must show blank screen. coz it receiving the vedio signal from TV.
hope you get the answer.
Aug 01, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
No picture
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Jan 31, 2009 | Yamaha DVD-S540 DVD Player
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
New Toshiba 37" flat screen always displays Closed Captions. Feature is turned off with TV remote, feature not available on Cable remote. Toshiba says it is Cable company problem, Mediacom cable can...
I've had this problem for a bit, it seems that there are two ways to turn off the closed captions.
1:Menu--->Preferences--->CC and Digital Audio Selectors. This displays the menu on the bottom of the screen with the choices of Closed Caption formats and digital audio. This is not the correct menu to be in. This turns off the CC as long as the TV is not turned off or the input is not changed. This is a temporarily either turns the CC on or off.
The Solution:
2:Menu--->Setup--->TV Settings--->Closed Captions Settings Displays a menu in the center of the screen, with the options of Turning the Closed Captions on and off, the Analog CC Mode and Digital CC settings. You must turn the Closed Captions off in this menu or the changes to CC are temporary.
For the record:
1. I'm aware I'm 2 years late on this, but I just want others to be able to solve this issue on their Toshiba. Don't worry, my Toshiba is the same age as yours
2. I've lost faith in Tech Support ages ago. I'm sorry that they were that incompetent.
3. Its ridiculous that there are two entirely different menus to alter the closed captions. Took me forever to figure this out.
Hope this helps you and others.
Jun 17, 2008 | Televison & Video
Cannot down TV Schedule
1. Press Menu on the remote. 2. Choose Setup from the menu. 3. Scroll to Connect to ReplayTV Service Now. 4. If you don't have this option try this. For ReplayTVs running older software: 1. First, exit any menus you're currently in. 2. Press "2-4-3" on the remote followed quickly by pressing the "Zones" button - this will launch an informational screen, with like a 1-Exit, 2-Clear the Channel, etc. 3. Select #7, 'Net Connect' from the menu. (#4 on ReplayTV 2000 or 3000 series). A message at the bottom of the tv screen will indicate a successful connection. If you are unable to force a connection using this method, you may need to reboot your unit. This is done by pressing and holding the "Power" button on the front of the unit for 10 seconds. (Note: When you hear the fan in the rear of the unit turn off, your unit is rebooting.) Now repeat the previous instructions to force a connection. This is all found on the support site:
Sep 22, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
JVC DVD player problem
You have set the DVD to progressive output for your big tv. The little one will not accept this. Your manual will tell you how to reset it. The remote may be needed. Reconnect it to the big tv and check the menus.
Sep 01, 2007 | JVC XV-N422S DVD Player
Toshiba RD-XS34 DVD Player/HDD Recorder Logo
192 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
