Panasonic Lumix  DMC-FX3 Digital Camera
Problem for Panasonic Lumix DMC-FX3 Digital Camera
Lumix fx30 wont turn on after i drop it
By paula_assunc on Jul 09, 2009
lumix fx30 wont turn on after i drop it
Best Solution
posted on Jul 13, 2009
Very Helpful)
Hacklet
Rank: Master
Rating: 93%, 5 votes
The first thing I would check would be the battery compartment, the Lumixes have horrible battery connectivity but can usually withstand some pretty heavy drops. Open the battery compartment and wiggle the battery about when you are turning it on and push it in slightly see if that helps. One of my Lumixes has about 3mm of tape on the end of the battery to force it in more now :)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 05, 2009
Not Rated)
dupalopez
Rank: Guru  Panasonic Expert
Rating: 94%, 24 votes
There are two logic boards on fx30, it is possible that due to the drop the upper board has disconnected itself from the bottom one. It is only held by a connector plug. It might be a good idea to check that.
If you're not afraid to tinker with things, try opening the camera (just the back of the case). Once the screws are undone, very carefully lift the back of the case a bit, you'll see two white ribbon cables. Disconnect them and once done you'll have free access to the logic board. Push on it evenly (do not press in one spot on the edge but try to spread the pressure evenly). Hopefully, that's it.
Hope this helps,
Raf
Was this helpful?
Yes
No
Popular Solutions for Panasonic Lumix DMC-FX3
Questions and Unsolved Problems for Panasonic Lumix DMC-FX3
Do you recommend Panasonic Lumix DMC-FX3 Digital Camera?
Answer
Answer
i need to download pictures from my Panasonic DMC FX18 campera and cant locate the software.
Answer
Panasonic Lumix DMC-FX 3 I dropped the camera and it still takes pictures but nothing shows up on... (More)
Answer
dirt or fungus inside of lens (or or on chip?). Visible only via LCD - and on photos.
Answer
panasonic DMC-FX3 turn lens come out but message please turn camera off and then on again. If you... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in , IL
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
