Question about PC Laptops
Keyboard problem I think, Hope! compaq pressario R4000
The notebook boots up fine and the mouse works but the keyboard is completley unresponsive, so I can't log in or redirect it to dos or setup, it had been working ok up until then.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Re: Keyboard problem I think, Hope! compaq pressario...
Try using an external keyboard and see if that works.
Posted on Nov 17, 2007
0 characters
3 Points
Compaq nc 6220 laptop keyboard water damaged and all keys unresponsive
We have all done it .It was a cup of tea that went over my last laptop and there was no way that I could repair it. If you have insurance cover on it specifically you may be able to claim, otherwise expensive repair.
Keyboards start around 19 pounds free postage on Amazon There are wireless ones too. Hope this helps Anna
Mar 02, 2013 | HP Compaq nc6220 Notebook
Problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
Nov 06, 2009 | HP Compaq Presario R4000 Notebook
Compaq r4000 dark screen
press F5 in the keyboard the light should be back or check the keyboard in the computer in the top botton where you see a sun design press that one you shoul have two of those 1 for put the light dark and the other one for put the light back good luck
Oct 13, 2009 | HP Compaq Presario R4000 Notebook
There is no driver from Compaq because it just uses a standard driver from the operating system.
Try removing the keyboard from the device manager.
Then restarting the computer.
Let me know what happens.
Feb 27, 2009 | HP Compaq Presario R4000 Notebook
Unlocking Numbers on keyboard of a Compaq Pressario c700 on Vista
you can use numlock button together with "Fn" button that is usually blue and locating keyboard down/left corner.
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq 2100 Laptop Monitor KBD & Mousepad (Not working)
The monitor is defective and should be repalced. Keyboard and mouse pad problem could be a driver problem. Try to reinstall their drivers.
Dec 02, 2008 | Compaq Presario 2100T Notebook
try draining the power by removing the ac adapter and battery and press and hold the power button for 10-15 secs then try again. if this doesnt works, then replace the keyboard.
hope this helps!
Mar 07, 2008 | HP Compaq Presario R4000 Notebook
Sounds like your builtin graphics controller went bad.
Dec 05, 2007 | HP Compaq Presario R4000 Notebook
R4000 keyboard problem
As a try try a restore point as far back as possible. Chgeck out your anivirus protection and trojan protection Any good A/V program and trojans try If all that fails it seems like a chip failure. but I suspect an infection of some kind.
May 13, 2007 | HP Compaq Presario R4000 Notebook
Presario R4000 Keyboard removal
Is this one of the keyboards that has the little plastic tabs that are springloaded holding it in at the top?
Oct 27, 2006 | HP Compaq Presario R4000 Notebook
PC Laptops Logo
314 people viewed this question
Top PC Laptops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Laptop Expert? Answer questions, earn points and help others
