Good Morning Joseph, thank you for your inquiry!
From what you have described your Frigidaire washer is displaying an error code of "48" and you would like to fix the issue. An "E48" error code stands for your control board thinking the door is closed. This could be a possible problem with your door lock assembly or the control panel. You may want to check the door latch to make sure there is no visible damage or loose wires. I would recommend consulting with a professional for proper repairs if the latch is not damaged. I hope this information is helpful. -Matt
SOURCE: Frigidaire Affinity ATF6000ES Error code E-48
you might have some thing in the pump check pump first if Therese nout in there then it might be your brashers you will have to look on ebay and don't for get to wright your model number down there really cheap if you get stuck get back to me i will help
SOURCE: washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
SOURCE: hi there, ive got an frigidaire washer atf6000es frnt load
yea board or latch)latch usually shows fault. the board is located left rear of unit, first ck for loose wire connection leading to it.
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
